well, my black comanche is still dead my sister and her husband wanna go wheel at a local spot with his new j10... iam bringin the red truck 2wd and all.... he has a tow strap.......this could get ugly
dang what color is your truck?it looks black outside but grey inside i like that grey its nice i wish i had the money for a full resto on my driver.. you should put a 97+ front end on your truck that would make it even better ;)
well the new header panel has a little bit different body line than the older header panel so if you want it to look right... youd have to change out the header panel.. fenders and bumper.. they pretty much all go together
i was lookin around on myjeepsite.com and ran accross this monster mj
i told the guy about comanchelcub.com maybe hell get on here ...until then here's a few pics of his mj..
i have the axle side of the 44 driveshaft and the transfercase side of my mj drive shaft...since iam doing a front leaf conversion i may have to lengthen it its not a on road truck ..offroad only... so if i just do it myself..without balancing it... would that be bad?
i tore down a donor block today and noticed a hole that iam not sure of...
iam thinking this may be a hole that the oil can come through for the timing chain and all iam not real sure so i figured id ask someone on here
Image Not Found
Image Not Found
Image Not Found
i got more goodies....
master engine rebuild kit
here's the kit
Image Not Found
here's the motor that gets it... the old one had a hole in the block
Image Not Found
haha na i havent yet its one i got a harbor freight on sale for $200 not bad i guess.. its a 130amp 220 volt tig/arc welder.. i will prolly use it this weekend for the perches on the 44 and bracing the front for the leafs
Image Not Found
Image Not Found
i got the 36s today... iam happy!
Image Not Found
Image Not Found
i also got a tig welder today... a locker for the front 44 and the 5.13 gears front and rear...
well a good welder may cost more than your truck, but you can make your truck alot better with it. to me its worth havin a good welder regaurdless of the price of your truck
iam going to harbor freight tools tommorow and picking up a tig welder they have there for $220 ill be using that for my leaf swap and bumpers...rollcage and whatever else needs to be welded
