Everything posted by GonzoTheGreat
I will admit that my understanding of this valve is a little hazy, but from the pictures I see no reason why it wouldn’t be rebuildable. I will also share that I’ve blown a rear line and had the shuttle block off the rear. I didn’t lose all my fluid, and although the pedal was soft, I still had front brakes. I fixed the line and bled the rear, I gave the pedal a final stomp just to feel if there’s any air in the lines, and when I turned the truck back on, the shuttle had returned to center and I didn’t have the light on on the dash. I never touched the front brakes during this process. Is it possible you didn’t slam the pedal hard enough to move the shuttle? I have never bled according to the book, so maybe someone else can speak for how much pressure it takes to move the shuttle while bleeding, but for me I was basically standing on the pedal after my line blew.
DYI Transmission Control Unit repair
GonzoTheGreat replied to Scottybbythesea's topic in MJ Tech: Modification and Repairs
That’s a good clean solder job. Thanks for the info! Also a hell of a lot cheaper than a replacement TCM. -
My bad. I totally misread this. I’m currently trying to solve this situation: if I get ahold of anything in Europe, would you be interested in good used front side markers @NHMJXJ?
Wait, were there euro tails for the MJ? I know XJs had them, and I’m actually looking for one now, but I didn’t think euro Comanches had something different for tail lights than us. also, well played:
1988 Golden Brick
GonzoTheGreat replied to Salvagedcircuit's topic in Member Projects: Your Comanches
I love the detailed posts on your build. It’s a really great read. Really good pictures too. but also, wait. wtf? A sandwich??? You found a sandwich in your floor?? -
Project Morris: The 89 to 99 Comanche Long Bed
GonzoTheGreat replied to RuBacon's topic in Member Projects: Your Comanches
This looks like it’s gonna be a good one! -
The whirring sound makes it seem like the starter is spinning, but not engaging the flywheel. Did this noise happen with the old starter as well? Or only once the new starter was installed? A difference between 4.0s and 2.5s is that the 2.5 uses shims under the starter motor. Did you have any shims under the old one? I had to adjust the shim pack on my 2.5 when I replaced the starter. again though, this is assuming the whirring noise accompanied the new starter.
August 2024 - Project Scuzzy
GonzoTheGreat replied to 89 MJ's topic in Comanche of the Month (MJOTM)
Aw hell yeah! This is one of my favorite builds! Congrats! -
Perfect! Thanks @eaglescout526!
I'm looking to source a “trail spare” alternator pulley. I don’t want to buy a whole new alternator for the sake of a pulley, but my current one is a little hogged out on center, and I’d like a decent spare just in case. This one is apparently a little hard to find. It’s got the 6 rib and v-belt combined. I’m hoping someone has an old 2.5L laying around and they’re not using it. The alternator doesn’t even have to work, I’m just looking for the pulley. Thanks
Headlights not working solution
GonzoTheGreat replied to moparbrown's topic in MJ Tech: DIY Projects and Write-Ups
I used this one from Jeep Cables, and I’ve had no complaints. It seems like high-quality wire, and the headlight sockets are ceramic. It made an incredible difference in the brightness of my headlights. -
1992 Jeep Comanche "Maria"
GonzoTheGreat replied to MariaManche's topic in Member Projects: Your Comanches
I used a chisel where it was more brittle, and wire wheels for the rest. It was messy. -
Quick update: The truck is legally abandoned. It will likely sit alongside the highway until next year when some kind of state-funded junk removal barge comes to clean the town up. Then it’s likely to be junked. It’s too bad this place is so isolated, because it could probably live again, in the right hands. Although the hood release is broken, and there’s a lot of stuff in the bed that should be under the hood. in other news, I couldn’t let these go to waste Aww yeah, that is, in fact, a cargo lamp! The small stuff will fit in my checked bag, but the tailgate is sneaked onto a pallet headed to Seattle. Not sure how I’m gonna retrieve that yet, but we’ll figure something out.
Hey guys, I’ll dig a bit more on NAXJA and maybe jeepforum, but I figured I’d ask here as well. Does anyone have a source for info on the late model XJ turbo diesel available to the euro market? I believe it was still made by Reneault in ‘97. Any info would be great. A repair manual would be ideal. Also, does anyone have a good source for parts here in North America or somewhere across the pond? I might be looking for cooling system parts specifically. Asking for a friend
I’ve had good luck with the dual gaskets, but I always give them a spritz with copper “spray-a-gasket” exhaust rated stuff.
I second that. A few bulbs isn’t much by todays standards, but when you’ve only got 60 amps from the alternator, and questionable aging grounds, it adds up. I used to have the same problem, but I’ve gone LED with every bulb except the front directionals. They had to stay incandescent to make the late-model turn signal mod work, and now I have electronic flashers to work with the LEDs. I also replaced the front turn signal sockets and headlight switch, and cleaned up/improved all my grounds. I also installed a headlight relay harness, but I don’t think that affects the directionals. I'm not sure which of these things fixed it, but the radio doesn’t dim anymore. I wish I could be more helpful, but I did everything in one go, so I couldn’t tell you what was the exact culprit.
You might be referring to the pre warmer. Does the hose have a spiral wire in it like a dryer vent hose? If so, it’s to draw hot air off the exhaust manifold into the air box during initial start up to bring the engine up to temp quicker.
I tied the positive wire for my third brake light to the ground side of the brake switch then chassis grounded the light. That seemed to do the trick for me.
I vote up top. I think it looks nicer.
June 2024 - The Travelling MJ
Thanks guys!!! This is an honor I’ve dreamed of since 2011. I’m happy to be a part of this community! If we head back to the states in the spring, how about I just stop by? -
89 Sportruck 2.5L 4-speed 2WD This one is in the yard across from Peninsula Automotive in Naknek, AK Unfortunately, it’s not going anywhere under its own power. Fortunately, there’s nowhere for it to go in this town anyway (no roads connect to the mainland), so it’ll probably sit in this yard until it dissolves back into the ground. There’s not much salvageable except the tailgate, but again, there’s no way to get things out of here without spending a fortune.
Not 100% sure on the last digit. It may be a 2, but the windshield was pretty messed up in that corner. This one is on the Alaska Peninsula Highway in Naknek, close to King Salmon, AK. 2.5, 4wd, stick shift It’s rough. Probably never going to move. I’m trying to find out who owns it to see if I can nab parts.
lol. Thanks! I have no shortage of adventures. I’m doing commercial fishing up in Alaska this season. Gotta pay for the next trip! Unfortunately, no MJs up here. Several XJs, 2 SJs, and a couple J10s though.
