manche
Everything posted by manche
  1. this is my bumper
  2. found a better bumper guard
  3. oke here is front and back
  4. antidisestablishmentarianism you all think
  5. yje litte tab clip that holds the lline set
  6. prayer be with ya hope she recovers good and well :thumbsup:
  7. i did my swap and bolts right in and for colum shift its just a little more work before and after
  8. you might want to see if the clutch on your fan is still good also you radiator isnt clogged
  9. also make sure if you throttle cable is not sticking mine was idling abtu 1300 rpms then found the cable was sticking in insulation
  10. how many pounds should the center bolt on spring be tightend?
  11. ya it say put leaf under the 2nd longest spring but i called um and they said it goes longest to shortest so idk if he ment after the load or before
  12. short so the AAL is above the overload?
  13. i just got a AAL kit and was wondering were do i place it in the pack ? on the very bottom or 2nd to last??
  14. bgan 3 inch lift pic be up in tomarrow beginning rear
  15. so besides the mud its good on everything else ? antidisestablishmentarianism are the extenders? and so i just need spacers on back then ?
  16. well um i want to ruun 31s with the 4:10 universaly for mud, trail riding, little bit of everything not any hardcore rock crawling anyone have pics of a 3inch ifted comanche with 31s?? i ordered a 3inch and i want a idea how much clearance ill have with 31s on it also would you recommend spacers or rims with BS
  17. even if i stick with 4.10 and 31X1050R15 tires will it suck or will i need spacers?? so is it worth getting bigger tires with a 3 inch i want to run these will they fit a 75xr15 rim http://www.jcwhitney.com/autoparts/Item ... 0000383155
  18. i know i was wondering if i can put the front axle and diff on with a 3.55 front and 4.10 rear till i hook the tranny and case
  19. so if i run a 3inch lift with spacers on front and back antidisestablishmentarianism size tire would ya recommend
  20. name all the stuff ill need to do this conversion also if i just decide to temp run the dana 35 with 4.10 on the dana 30 3.55 will i will be able to drive it with 2wd till i get tranfercase and tranny hooked up
  21. can i still use my ax-5 if i get 4.10 rear and front
  22. why do peep say that the 31's are same as 235's?
  23. Is a 3inch lift gonna make a big difference 4x4ing like will my cleance be better then stock and antidisestablishmentarianism size tires can i get under it i got p235x75xr15 :dunno:
  24. woops here the right link http://phoenix.craigslist.org/nph/cto/1004244771.html
