manche
Everything posted by manche
  1. i hit a javelina today while i was racing a ford ranger out in the desert and luckily not much done but a slight bend in my brush guard :mad: nice find on all the gear did you convert the 95 speedometer with the cable or did you convert to electric?
  2. got new stabalizer in a rancho the od one had no resist and no gas in it
  3. is this a good deal on a dana 30 and will it work on a MJ so i can start my 4x4 conversion on my 87 sportruck http://phoenix.craigslist.org/nph/pts/989362528.html
  4. ok seems simple enough do you think the lift is decent in your opinion? and with this lift will running 235x75x15 tire is g0od for temp till i get newer 31's?
  5. hello i finally got my 3 inch lift kit and i was wondering antidisestablishmentarianism is the easiest way to take the origanal ones out and put the new ones in and same for the add a leaf
  6. does black diamond make a good 3" kit?
  7. ok then if i got wit the RC then antidisestablishmentarianism tools willi need and wats the difficulty 1-10 , 10 being the hardest :???:
  8. i got mine out of a 1990 and i got a 89 and it al works good :chillin: but after i get lifted and run 31's ill have to change the dang speedo gear :fs1: i already am running 235x75x15 and my speedo is off by 5mph like I'm going 50 speedo reads 45 :hmm:
  9. thats a xj kit
  10. next is to put on a new stablizer then wait for my lift to come in
  11. its the factory one i need to update the stereo becuase the speaker are way ahead ofits timeand thanx for the compliment i hated the switches but ill find a use for the L.E.D lights
  12. I'm just looking for a trail rig not to do hard core stuff thats why I'm looking for a cheapy lift thats why i ask of the two wats best andwat includes everything neededbut ill probally get a RE lift for my new Comanche this is just a project truck besides most stuff in AZ is just rocks and fear of bottoming out i plan on buying a better comanche that looks better and has a 4.0l then it will be worth every penny
  13. so is the rough country worth buying and antidisestablishmentarianism else would i need if i just use antidisestablishmentarianism comes in the kit??
  14. you think its a better price
  15. what kit of these two is the best ?? http://www.rocky-road.com/comanche.html or http://4wdtruck.com/jeepparts/index.php ... e964932024
  16. i took it out of a 4.0l cherokee the 2.5l had the same wheel as the comanche
  17. yea both temp and oill i replace but i broke the dummy light temp sender off in block and had to easy out it then i put the new sensor in and the oil sender i replaced i took one from a 4.0l cherokee and it all works :chillin:
  18. yea its just a pain putting the oil sender in :fs1: but beside that its a breeze just got to get a cluster with the right speedo clip as yours
  19. it was a pain putting the oil sender in in the 2.5l its under the compressor and rad hoses v :fs1:
  20. the old and new
  21. well just got a new xj guage cluster and a xj steering wheel and factory radio now to install will have pics up in morning here is my old setup
  22. yes they did most were on the 4.0l equiped but you can take a cherokees guages and put it in and just swap you speedo into the new cluster and get the correct oil and temp sensor for the guages and not lights i just did this to mine ill have pics up also here is a reference http://www.naxja.org/forum/showthread.php?t=921205 for the odometer :cheers:
  23. I'm going to JY and hopefully find a radio or bulb :ack:
  24. so how hard would it be :???: and what kind of bulb :dunno:
