87manche
Everything posted by 87manche
  1. input gear should be about $150 if you look around. Still though, I'd grab the case if they want anything less than $250 for it, then you can keep the other for a spare, or sell it.
  2. I've simply pared the key ring down. There's 3 keys on the ring in my pocket. both truck keys, and a house key. I've got a biner with the rest of work/house/wife's car keys that lives in the glove box.
  3. No can do. I have zero cash and these were given to me. So, I'm working with what I've got. Maybe I'll put it near the stock antenna, but on the driver's side. I think that's where I'm going to move mine. A simple bracket to bolt it to the inside of the fender and bring it out the gap between the hood and the fender.
  4. possibly. If it ran out of fluid you could have toasted it, the fluid lubricates the pump as well as providing pressure for the power steering. If it fails you 'll loose the power steering, as long as it doesn't seize you can still drive the truck, you'll just have to work harder at low speeds. If you're rally concerned replace it, it's not a hard task, just make sure you get the rental pulley puller at the parts store. Pull the pulley from the old pump, put on new pump, bolt it in . If I were going to do the pump I'd probably do the other line as well. Chances are it will fall apart when you take it apart.
  5. 87manche
    mmmmm tires.
    indeed, of the Bias Ply variety. http://intercotire.com/site32.php
  6. you can order the GM style lock cylinders from JC whitney. They're cheap and come with the key.
  7. those numbers sound right, I'd also cheak for a ground with high resistance. Ground for th tail lights should be behind the drivers side one.
  8. 87manche
    mmmmm tires.
    34x9.5 about 85-90 % tread left, it's deep. Like 13/16
  9. 87manche
    mmmmm tires.
    Gnarly fender trimming to hapen this weekend. Picked up the set on rock crawler rims for $450. Makes the 31's look tiny :)
  10. Hmmmmm, is Bill Gates actually a Comanche owner from Ohio? don't insult me. I've used opera since version 3. Yes, I am an internet elitist :D
  11. firefox sucks.
  12. you're not making any sense. Not having a trackbar is why it's not centered. Without the trackbar the front end is only kept under the truck by the control arms, and they can't locate the axle side to side, just front to back.
  13. I'd just stick a 2.5 in it. Hop up the 2.5 a little and you'll get more out of it than the 2.8 And it won't fall apart.
  14. If you don't have your trackbar attached then there's no way you can center the axle with the draglink. lifting the suspension will make your track bar and draglink SHORT. Simple geometry.
  15. might be, maybe 18" is for the XJ
  16. a spider gear replacement is your best bet. pop out carrier, replace spider gears with locker, put carrier back in. no gear setup involved.
  17. an djustable track bar for your amount of lift will certainly fix the problem. Most manufacturers sell them for 0-3" and 3-6" of lift. It would be prudent to measure how much lift you really have. If you've not vut the flare then you can measure from the flare to the center of the wheel. Stock is about 18" IIRC
  18. luckily the local advance guys don't ask me questions anymore. They just get what I want. WHen I asked for the flex line from a mid 90's dakota he asked me what the hardline size was, I confirmed that it was right and he went and got it for me. they stopped asking questions when I told them that I had a 97 axle with 90 knuckles and 97 rotors and hubs.
  19. I've only been there once or twice. Don't really like going to the movies. it's set so far back from anything else I bet they have problems with thievery. Not hard to know when the showtimes are and when people aren't going to be in the parking lot. WOuldn't surprise me if it was an employee.
  20. ditch the crazy molded steel pipe contraption and replace with good heater hose and fittings.
  21. somebody used eddie buaer exploder flares on an XJ, looked good. I was thinking about ath for when I ack my junk up. I'll prolly got TJ flare thogh.
  22. well, that's good to know. Must be lower because it's only got to feed one injector.
  23. 87manche
    Gas Tank Fun
    Uh, a grand? :roll: Might wanna fix that typo. :D might now, if someone's willing to pay that :)
  24. You over at te new place behind the best buy complex? yea i was in mansfeild at the movies. and with how nice of a movie place you would think they would have cameras, but nooo. and id rather keep my windows too then be cold or wet. and thats funny with the z-28. Alex
