My Badass Metric-Ton Comanche Build! (The End)
hey all!
I'm back with my 4th comanche,
plans are,
finish the 4wd swap,
install the d44 with electronic locker,
and install my bush bumper with 8000lb winch.
then after all thats done,
now with the pics i have :banana:
first off bye to my other two :(
  • Replies 124
  • 3 weeks later...
slowly but surely things are coming together,
get the last of my bushings tomorrow for the front and the the front will be finished,
spent all weekend with a torch and a bfh trying to get those damn sway bar link bolts out,
went to the h/w store and picked up a pit man arm puller,
popped out in a matter of seconds :thumbsup:
also picked up another flaring set just for the double flare dies :D
the finished product,
extended brake lines, new fittings flared on,
sway bar disconnect links + bolts installed,
had to haggle with the people down at lordco to get the bushings XD
I'm getting good at repairing tie rods,
found that the p/o sheared the cotter pins out and left em finger tight,
so extensive drilling/hammering and they are like new :D
and i scored this baby for 3 slices of pizza :D
looks like I'm getting a dual battery set up :jump:
more to come, going to swap trannys soon.
got the tranny out! :D
woulda had it out yesterday but i didnt have the e12 torx bit :ack:
Drive shaft out
starter off
broke 2 bolts, going to have to use the stock x-member,
the new one has 4 mounting holes instead of 8.
freakin expensive socket!
to tackle the top 2 bolts
out and carted away,
didnt stay on cart to long found carrying it much more effective
clutch has seen better days, but it will last for a while,
until i get more money ofcourse!
done for today
another project,
i don't wana torch em out, ill see if i can mock up a home brew bearing press
the heim joint is in the frame,
and the rubber busing with the adjustment is on the axle,
the heim joint has a press fit bolt in it, only bolts into the frame,
i did not install it, but thats how the track bar is oriented,
the track bar looks more like a rear zj track bar for lift,
adjustment on the bushing side.
Looks to me like it's the RE1660 tracbar. If it is, it's upside down and is missing the required RE1665 bracket.
it is not
I'm looking really hard, and I see no heim on the frame end. just a welded piece with a rubber bushing.
cam I'm not an idiot,
may not be a heim,
BUT, I WAS CORRECT.
it is a rear zj track bar,
I'm not @#$%ing stupid.
http://fatbobsgarage.com/i-6785322-jeep ... ation.html
so where is this rubber bushing you see on my frame?
took closer pics so you can stare at it longer if you would like
still think its backwards?
didnt think so.
