I tryied searching on this site but could not come across what i was looking for.
I'm redoing my vc, new ccv stuff, paint and cleaning. just wondering what i should torque the bolts to, too properly seat the new gasket? Is the tightening pattern the same as the cylinder head? Thats the system i used to remove it. Middle out wards.
any help would be appreciated.
Cheers,
with RTV 28in-lbs
with gasket 55 in-lbs
same as head sequence for tighting
Invest in a manual if not already have one, long road you about to travel down. :cheers:
Sweet thanx. I got some kind of 60$ felpro gasket myself. and 55 in-lbs sounds about right. To bad my torque wrench is half in and in ft-lbs.
well 55/12 = 4.6 ft-lbs right. Would i mess stuff up if i went to 5 ft-lbs?
Hand tight; where you can grasp and grip the part is usually 3-4 ft lb. after you've turned it as far as you can. Finger tight; where you use the tips of your fingers to tighten the nut/bolt is usually around 1 ft lb. Put your socket and extension on the nuts and turn them down by hand as tight as you can in the sequence MiNi Beast suggested. Then take an open end wrench and watch the hex on the bolt head and just tighten it by moving it 1/16th of an inch. That should put you really close, 5 -6 ftlbs won't hurt it but 10 ft lbs may break it.
i have a torque wrench I just didnt know if it would be a little different with the rubber gasket instead of cork
cork you need be more cation or else it will crack, there cheap temp fix, but the specs are the same, it's spec for permanent gasket.
i usually go about hand tight. but i have gone to far and cracked the pos plastic valve cover. wish there were metal ones for a 2.5
So to get the right torque i did an Azz kinda move. Bought a torque wrench from Canadian tire :Canadaflag: and returned it after i got the vc tightened down. :oops:
With some cleaning an painting. THe hole point of this was to stop my blow by. Replaced the ccv stuff two. Well put 300km on it know leaks and blow buy finggers are crossed.
Does that gasket have metal inserts where the bolts go through?? If so I don't think you have to worry about torquing it down to much. The metal keeps you from crushing the gasket.
Sure does. hmm i never considered that, but then again i never opened the gasket box before i got the wrench. Ya thats my week defence lol. I'll have to remeber that for my next vc job, thanx.
Cheers,
If you're going to work on your truck any more, you might as well buy a torque wrench and keep it. They have more uses than valve cover bolts. :wrench:
I realy realy wanted to keep it but, well i'm just broke. I can't even aford gas for the mj. :oops: I'm always realy hard on cash the end of the school year. But its all good i start my sweet internship job Monday and that means two weeks till payday :cheers:
I do have a nice craftman ft-lb torque wrench which i proudly display in the garage.
Cheers,
