2.5L mpg
SaharaTJ
i was wondering what some of you guys with the 2.5L get as far as mpg? So i know what I'm looking for as far as gas. I know its a jeep so real good mpg is outta the question but I'm trying to see if the mj will do better than my tj.
Wha??? 30-35?? I gotta go get me some of that Ohio gas-o-lean :D
I get an average of 18-20 in mixed driving (that's with the CAD shimmed over and pass side axleshaft locked full-time).
Back when it was a 2WD (and had a few thousand less miles on it), 23-25 mpg wasn't uncommon :cry:
YMMV,
Jeff
I would be more than happy with 20 to 25 mpg. I am estimating about 14-16 mpg mixed driving in my tj but I'm not sure cuz my speedo is off and I'm too lazy to swap out speedo gears that and I'm so used to it being off i don't know what i would do if i had the actual speed. And it will be a 5 speed 4x4 so I'm hoping for 20+ just hope I'm lucky!
Actually, mine's a 5 speed, not an auto. I've stepped up to 235's from the stock 205's (but I've changed my speedo gear). But I've discovered that leaving it in 4th more often as opposed to shifting into OD is helping economy-wise. I only use 5th now on the interstate, everything else I stay in 4th (unless coasting on a downgrade).
I'm moving up to 31's when I regear to 4.56's...I'm hoping it'll basically be a wash and things won't really change that much mileagewise. Normally my MJ isn't my DD, but it has been for the last couple of weeks :oops: I used to drive it about 1X a week. But one thing I've noticed now that I'm driving it daily as a commuter vehicle (LOL) is that the more I drive it, the better the gas mileage is getting :nuts: I dunno, I guess things are "loosening up" some the more I drive it, and it's going down the road more smoothly. Trust me, I ain't complaining!!
Jeff
you know that if you leave the tailgate up you get even better gas milage then with it down or off. mythbusters proved it. if you want it explained it goes something like this. with the tailgate up there is a sort of cyclone in the bed behind the cab that keeps the fast moving air going over the bed. with the tailgate down that cyclone isnt there so the fast moving air hits the tailgate or bed and creates drag. and there you have it. :chillin:
alex
alex
Come on, Pete... Post the 'highly technical artists rendering' You know you want to.(I really could use the laugh)
well i didnt want to post it and look like I'm too technical for everyone but i figured with the gas prices today i would post it since it was proven. plus i mean you might get about 30 more miles like they did.
alex
Unfortunately Mythbusters didn't actually "prove" anything. A single experiment on the highway does not a "scientific study" make. And the "water tunnel" didn't actually prove anything except that the little vortex does form. According to what they showed on TV, it's pure speculation that the vortex has anything to do with drag. They should have tried to measure drag on the little model or run the highway test over and over and over again to eliminate all those other variables they didn't take into account.
Now, I do believe that the tailgate is better up than down, but not because I watched the show. Auto manufacturers are desperate for every little mpg they can squeeze out of their thirsty pickups and if they could get a gain out of breeze-through tailgates, I'm sure they'd do it. I mean, they spent millions on MDS. Propping the tailgate open is, well, free.
i saw the show and wasn't it a newer truck mine is an 88 not new thay wern't that woried about it then it wasn't an mj and i didn't put gate down it don't have one lol i havn't made it yetso it don't matter lol
this is totally off-topic from mj gas mileage but its completely nuts so ill post it anyways
my bro is running a 90 renix 4.0 XJ with 220+k miles on it blowby like crazy bad compression gas gets in the oil (way past due for a rebuild but a strokers on its way) pushin 33" superswampers with 3.55s and AW4 and he gets... drumroll
19-24mpg
:nuts:
