SUPER Rare XJ/MJ Gauge Cluster w. Police Speedo on FleaBay
Has the police model 115MPH speedo and the window for the column shift AW4 shift indicator in the gas gauge. Only 91+ MJ/XJ owners can apply (electronic speedo). :D
Item # 110241418796. No it's not mine!
Cool!!! Whats that idle switch do exactly?
It simply applies a ground to a pin on the ECU (haven't schematic-ed it out yet) that raises the idle RPM about 500 more than normal so the cops can have increased donut munching time w/o overheating. Prolly back to closed loop, but I'm not sure. But I do have one of these speedos and will be installing it shortly. I'm told the police speedo built-in circuit board logics the frequency of the sender into correct needle deflection w/o mods to indicate correct speed. I'll know soon........ :D
So the idle switch will when flip give you a high idle?
My buddy, Dune Coon, did something of this sort. He installed a silnoid on his trottle linkage on body so you flip a switch and it bumps the idle up, this being for his winch and duel batters and all his dang lights. picture of his ride under my build. It's a pretty sweet set up. Going to do the same down the road
yeah it bumps the idle up to give you more charging power from the alternater so you can run larger electrical loads without draining the battery
My buddy, Dune Coon, did something of this sort. He installed a solenoid on his throttle linkage on body so you flip a switch and it bumps the idle up, this being for his winch and duel batters and all his dang lights. picture of his ride under my build. It's a pretty sweet set up. Going to do the same down the road
You have a stick no? If your crawling in the rocks, you SHOULD have a hand throttle anyway. Unless you have three feet! :roll: :eek: :D It takes a bit to get used to, but when you need it its like pure gold!!!
I also use it to govern my throttle in the TJ for heavy /long winching and "jumping" another jeeper etc. Its very slick and no electricity is needed.
CW
Well if you guys aren't going to bid then I just will... I'll swap in a tach and sell it back on ebay..
Errr, that won't work JT, unless you swap out the circuit foil piece on the back of the cluster. On the tach-less clusters there is no provision for the tach input from the connector.
I know I meant to say i'd swap the speedo,,, or I might just use it,,, I have a electro speedometer cable..
well crap..... someone snuck up and snatched it up,, I swear I was winning with 4sec's left... oh well.... I really didnt want it.. I hope the guy who got it likes the fact I pushed the price up on it!! hehe. I was really just wanting the cool switch!! lol
i'll sell you the switch.
You bought it???????? ughhhhhhhh...:headpop: :mad: :hateputers: :rant: :grrrr: . kidding.. You should have told me I'd let you have it for the bid I had.. I really didnt want it, just couldn't sit and watch it sale for 20 bucks!! lol
actually you didn't drive up the price, two people bid 30 for it. So i was going to pay what i did either way.
Cool... I just saw the bid history.. your right.. I still feel bad though.. :roll:
At least it will go in a MJ!!!
Man, I'm surprised the XJ guys didn't jump on that cluster. Not many left....
Man you know those guys can't read.... duh... j/kin.. For about 4 sec's I though I was going to be stuck with a gauge cluster I really didnt need...
CW
Yeah that is why I was going to switch out the tranny for a auto when I first got her, but was told not to, but I hated wheeling it. But now that I know how to work the clutch I love it and will never go for a auto. But yeah was looking into a hand throttle being, not much rocks up here, but will be moving to AL, south, I will be looking for some rocks, but yeah atleast a throttle bump for the accessories none the least.
