reson46 Posted August 4, 2008 Author Share Posted August 4, 2008 :eek: reinforcement I hope? You don't think it will hold up? :???: I'm going to add a piece of 6" C channel to the front cross member, then build a bumper around the entire thing. I don't expect sheet metal to handle the pressure of a winch. ;) Willy Link to comment Share on other sites More sharing options...
MiNi Beast Posted August 4, 2008 Share Posted August 4, 2008 :eek: reinforcement I hope? You don't think it will hold up? :???: I'm going to add a piece of 6" C channel to the front cross member, then build a bumper around the entire thing. I don't expect sheet metal to handle the pressure of a winch. ;) Willy :laughin: I know but wanted to sure it was posted so someone checking it out this far don't jump the gun and go do it them selves then expect it to work. :roll: Link to comment Share on other sites More sharing options...
reson46 Posted August 6, 2008 Author Share Posted August 6, 2008 Opened up the hole in the cross member for the winch line to feed through. Willy Link to comment Share on other sites More sharing options...
reson46 Posted August 6, 2008 Author Share Posted August 6, 2008 :eek: reinforcement I hope? I think this will do a pretty good job of reinforcing it. :D Willy Link to comment Share on other sites More sharing options...
reson46 Posted August 11, 2008 Author Share Posted August 11, 2008 I tapered the ends of the C channel. Added some extra supports. Willy Link to comment Share on other sites More sharing options...
reson46 Posted August 11, 2008 Author Share Posted August 11, 2008 Started the bumper. This gives a rough idea of the approach angle. It may even be better than with the stock bumper. One of the side brackets. I'm using all of the steering box bolts and going clear back to the large hole a little further back. The hole on the right will be for a D-ring mount. I would actually prefer to not have the D-ring mount sticking off the front, but I couldn't think of a better way to incorporate a tow point. I could have added a tow hook underneath similar to the mounting for most tow hook brackets, but I like the upside down tow hooks even less than the D-ring mounts. :dunno: Willy Link to comment Share on other sites More sharing options...
reson46 Posted August 13, 2008 Author Share Posted August 13, 2008 Made a hole for the fairlead. Passenger side bracket. Driver side bracket. Now it is starting to look like a bumper. :D Willy Link to comment Share on other sites More sharing options...
89eliminator Posted August 14, 2008 Share Posted August 14, 2008 nice work. Link to comment Share on other sites More sharing options...
Wanderin Posted August 14, 2008 Share Posted August 14, 2008 I like the way you have mounted that winch, and great pics. Link to comment Share on other sites More sharing options...
reson46 Posted August 14, 2008 Author Share Posted August 14, 2008 Thanks guys. This is the fun part. Putting all the pieces together and watching it take shape. :D Willy Link to comment Share on other sites More sharing options...
reson46 Posted August 18, 2008 Author Share Posted August 18, 2008 I tied the brackets into the sway bar mount. Added the side tubing. Created a ramp along the bottom to help slide over things. Willy Link to comment Share on other sites More sharing options...
JohnQ Posted August 18, 2008 Share Posted August 18, 2008 Looking good. So when can you make me the same bumper? :D Link to comment Share on other sites More sharing options...
Throttle_Jockey Posted August 19, 2008 Share Posted August 19, 2008 Nice job you gave me some good ideas on the angle I would like to go with mine 8) Link to comment Share on other sites More sharing options...
reson46 Posted August 19, 2008 Author Share Posted August 19, 2008 Looking good. So when can you make me the same bumper? :D Thanks, but I think I'm going to take a break before I start another big project. :D Willy Link to comment Share on other sites More sharing options...
reson46 Posted August 19, 2008 Author Share Posted August 19, 2008 Built up the sides a little. Willy Link to comment Share on other sites More sharing options...
Casper2000 Posted August 19, 2008 Share Posted August 19, 2008 Looks good 8) How heavy is it ? Link to comment Share on other sites More sharing options...
reson46 Posted August 19, 2008 Author Share Posted August 19, 2008 Looks good 8) How heavy is it ? No idea yet. I haven't taken it off to finish welding it. Willy Link to comment Share on other sites More sharing options...
jackel18 Posted August 20, 2008 Share Posted August 20, 2008 Have you mounted the rear bumper yet? if so could you post some pics? i like the idea i just want to see how it looks before i decide to cut my rig up. Thanks Rich Link to comment Share on other sites More sharing options...
reson46 Posted August 20, 2008 Author Share Posted August 20, 2008 Have you mounted the rear bumper yet? if so could you post some pics? i like the idea i just want to see how it looks before i decide to cut my rig up. Thanks Rich It is currently sitting to the side waiting for paint. Once I pull the front bumper off for finish welding I'll pull the MJ out of the garage so that I have room to paint it. Willy Link to comment Share on other sites More sharing options...
jackel18 Posted August 20, 2008 Share Posted August 20, 2008 cool. Nice work man Link to comment Share on other sites More sharing options...
reson46 Posted August 27, 2008 Author Share Posted August 27, 2008 Pulled off the front bumper and started welding. Spent some time with the grinder. Added gussets to the side tubes. Willy Link to comment Share on other sites More sharing options...
G Hunt Posted August 28, 2008 Share Posted August 28, 2008 how do you like the ecteds? So far so good. Only one wheeling trip with it at this point, but they worked well. Very quiet. No clunk or anything when they engage. Willy Hey what is a website or how does a guy in utah get one of those belly pans and there frame strengtheners it there a website or a phone number that i could call cause i like that belly pan and I have access to build and bend my own arms and great project I like how you have done everythimg with it!!!! Link to comment Share on other sites More sharing options...
reson46 Posted August 28, 2008 Author Share Posted August 28, 2008 Hey what is a website or how does a guy in utah get one of those belly pans and there frame strengtheners it there a website or a phone number that i could call cause i like that belly pan and I have access to build and bend my own arms and great project I like how you have done everythimg with it!!!! Thanks! Here is their web site. This is the belly pan. It doesn't list the control arm mounts for the belly pan so I would ask them to send you one with the mounts if you plan to attach your control arms to their belly pan. They are very helpful. They lengthened my belly pan so that it would protect both of my transfer cases. They also offer the Y-Link upgrade that you may want to consider. It includes the belly pan and the long arms unless you just really want to make your own arms. This is the route I went. They currently don't offer the unibody stiffeners for MJs, only XJs. I asked if they would work on MJs when I ordered the suspension. They said they could be made to work, but there are so many differences between the unirails that it would be more worthwhile to make your own. Willy Link to comment Share on other sites More sharing options...
G Hunt Posted August 29, 2008 Share Posted August 29, 2008 Hey what is a website or how does a guy in utah get one of those belly pans and there frame strengtheners it there a website or a phone number that i could call cause i like that belly pan and I have access to build and bend my own arms and great project I like how you have done everythimg with it!!!! Thanks! Here is their web site. This is the belly pan. It doesn't list the control arm mounts for the belly pan so I would ask them to send you one with the mounts if you plan to attach your control arms to their belly pan. They are very helpful. They lengthened my belly pan so that it would protect both of my transfer cases. They also offer the Y-Link upgrade that you may want to consider. It includes the belly pan and the long arms unless you just really want to make your own arms. This is the route I went. They currently don't offer the unibody stiffeners for MJs, only XJs. I asked if they would work on MJs when I ordered the suspension. They said they could be made to work, but there are so many differences between the unirails that it would be more worthwhile to make your own. Willy Thanks for the link to there website I guess a poor college kid like me better start saving some money to afford there product!! So far how are you liking it and the mounting to the weak frame thing it looks pretty strong but that stupid uni body just makes me wonder when it comes to hookin something up to it thanks again G Hunt Link to comment Share on other sites More sharing options...
