jtdesigns Posted January 24, 2008 Posted January 24, 2008 Firefox users.. I found a great lil tip to make firefox way mo speedier! here's what you do Thanks Hippy; type: "about:config" (without quotes) In address bar press [Enter] Double click on and set the following. browser.tabs.showSingleWindowModePrefs = true browser.xul.error_pages.enabled = true network.dns.disableIPv6 = true network.http.max-connections 48 network.http.max-connections-per-server 24 network.http.max-persistent-connections-per-proxy 12 network.http.max-persistent-connections-per-server 6 network.http.pipelining = true network.http.pipelining.maxrequests 32 Hit the refresh button and close the window... million times faster then before!!! If your running a lil slow as I was!
SuperWade2 Posted January 24, 2008 Posted January 24, 2008 about:config Without the space between the "t" and the ":"
jtdesigns Posted January 24, 2008 Author Posted January 24, 2008 about:config Without the space between the "t" and the ":" Thanks!! Yeah without the space.. good catch!
MiNi Beast Posted January 25, 2008 Posted January 25, 2008 thanks for the tip it's lots faster. Very nice.
LJRockstar Posted January 25, 2008 Posted January 25, 2008 THANKS!!!! That is a great tip! I couldn't find this one though. browser.tabs.showSingleWindowModePrefs = true But it switched all of the others and it is WAY faster!
Badger Posted January 25, 2008 Posted January 25, 2008 Just download the 'fasterfox' add-on yep it pretty much does the same thing with out having to go into the config.
