ghetdjc320 Posted 7 hours ago Posted 7 hours ago For any that have done a jk front 44 swap, I’m curious to know what you did for the track bar. I’m wanting to keep stock style JK steering design with the dragline under the steering arm (no high steer) and keep my 3.5” lift. Most track bar setups I see for this swap are for high steer
derf Posted 6 hours ago Posted 6 hours ago I'm not doing a JK axle so not 100% the same. But I'm going to set up my track bar after I finish the rest of the steering. I'll adjust either the frame side, axle side, or both once I have a drag link in place. I'll adjust what I can so they end up as parallel to each other as possible. If you have a higher mount point for the axle side of the track bar but you use a drop pitman arm, you may be good with leaving the frame side at stock height.
Eagle_SX4 Posted 5 hours ago Posted 5 hours ago This may not be helpful but Barnes4wd sells a JK44 truss swap kit. It appears they have the track bar mount close to the factory (XJ/MJ) location. https://barnes4wd.com/products/jeep-jk-dana-44-to-jeep-tj-lj-xj-zj-or-mj-front-axle-swap-kit?srsltid=AYCX9vJLNJcMt3YCi3PSP1-XdeLoy-jhXcNWrTiKeABGzle1JKyoR7Ko
ThatJeepGuy Posted 4 hours ago Posted 4 hours ago 1 hour ago, derf said: I'm not doing a JK axle so not 100% the same. But I'm going to set up my track bar after I finish the rest of the steering. I'll adjust either the frame side, axle side, or both once I have a drag link in place. I'll adjust what I can so they end up as parallel to each other as possible. If you have a higher mount point for the axle side of the track bar but you use a drop pitman arm, you may be good with leaving the frame side at stock height. This is a great approach, get the axle you want under it and then see where/how things line up and then address from there. let's be clear, the axle will go under the jeep with some adaptation. How you adapt it is on you. Obviously parallel is a must but also shoot for keeping the steer link and track bar as close to the same length as you can. Id also argue to avoid drop pitman arms as well - longer "drop" adds leverage against the unibody which is something you should try and avoid. Keeping them as close to the same length also reduces the bind between the difference in arc between them.
derf Posted 3 hours ago Posted 3 hours ago 57 minutes ago, ThatJeepGuy said: This is a great approach, get the axle you want under it and then see where/how things line up and then address from there. let's be clear, the axle will go under the jeep with some adaptation. How you adapt it is on you. Obviously parallel is a must but also shoot for keeping the steer link and track bar as close to the same length as you can. Id also argue to avoid drop pitman arms as well - longer "drop" adds leverage against the unibody which is something you should try and avoid. Keeping them as close to the same length also reduces the bind between the difference in arc between them. Yep. All good advice. My axle swap is different enough from a JK axle. And I'm going 4½" on my lift. My truss has a stock location track bar mount axle side. But I'm doing high steer and upgrading to 1 ton parts. I'll keep the stock pitman arm. I may decide to put a higher axle side mount for the track bar. But if I do, I start getting into the coil bucket. So it's more likely I'll drop the frame side instead. I want to upgrade that anyway and a lot of those kits build in a drop.
Big_Mark Posted 2 hours ago Posted 2 hours ago Thanks for posting up fellas, now that I have new tires and a winch, I'm starting to look at a front locker, seems like the PO did do an upgrade on my MJ, but he just swapped out a peeneey Dana 30 without the vacuum axle bits. Peeney = 3:55 gears with the smallest spline count you can get, lol. This swap kit gives me hope, I look forward to some pics to see the results of your efforts. Good luck!!
