ComancheX2 Posted November 15 Posted November 15 I started to do my first oil change on my new to me MJ. I'm having a heck of a time trying to get to where I can position the wrench and get any movement. The cap type wrench didn't want to stay on, so I got a chain type and between the engine mount, the distributor, and the evaporator canister I can't get to where I have enough movement. Anyone have any tips & tricks they'd be willing to share? My '94 XJ has the filter horizontally I'd reach up from underneath and never had any issues with it.
fiatslug87 Posted November 15 Posted November 15 I use this type of filter wrench, works great on the vertical filter.
ComancheX2 Posted November 15 Author Posted November 15 Thanks a bunch! I haven't seen that type before. Does the adjusting the nut on the end draw the jaws in tight?
fiatslug87 Posted November 15 Posted November 15 They self adjust and lock into place as you turn the ratchet.
llhat Posted November 15 Posted November 15 my 89 filter vertical, have always been able to use a regular strap wrench ( thin metal band) with a lever on it. you have to take small bites and position the handle in the 'right' place to apply pressure.. My "first" 4.0 filter in November 1990 on a cherokee... brand new, few thousand miles.. changed oil (early) just before a trip the following day to Hatteras Island I 'slipped' and the wrench i was using hit the distributor cap... OOPS... was lucky to have some really good contacts at local NAPA.. one fellow was in the store after hours restocking shelves.. He let me in and put a cap on my account.. took it home and installed.. never made 'that' mistake again on numerous oil changes ever since....
Pete M Posted November 15 Posted November 15 one time I had a filter that didn't quite fit the cap wrench and got it to work by putting a couple rubber gloves between the 2 for grip.
ComancheX2 Posted November 16 Author Posted November 16 Thanks Ilhat, sound like you may have the same luck as I do! ;) Pete, the rubber glove is a good idea! I did a search for the type Fiat posted. I couldn't find the same one, but did find a Lisle 63250 in stock at one of the three autoparts stores and ran in and grabbed it. It sure was tight, but finally managed to break it loose. Now that the filter is off, it does have metric threads. I had a couple of the filters from my XJ I was thinking I'd use, but I'll have to make another trip into town to find the correct one.
Eagle_SX4 Posted November 16 Posted November 16 Check this out you can swap to the standard thread filter.
ComancheX2 Posted November 16 Author Posted November 16 Thanks Eagle, I wasn't sure if it had been changed over yet. I think it will be convenient to change it over for commonality being that I have an XJ too, but for the moment, I'll get a metric filter to get it going. I've got several things I want to do and it would probably be smart to get them done first before winter sets in. 1) reconnect the parking brake the PO didn't hook back up after they installed the lift. 2) replace any wear components needed in the suspension steering systems 3) do a brake job
