ComancheX2 Posted 3 hours ago Posted 3 hours ago I started to do my first oil change on my new to me MJ. I'm having a heck of a time trying to get to where I can position the wrench and get any movement. The cap type wrench didn't want to stay on, so I got a chain type and between the engine mount, the distributor, and the evaporator canister I can't get to where I have enough movement. Anyone have any tips & tricks they'd be willing to share? My '94 XJ has the filter horizontally I'd reach up from underneath and never had any issues with it.
fiatslug87 Posted 2 hours ago Posted 2 hours ago I use this type of filter wrench, works great on the vertical filter.
ComancheX2 Posted 2 hours ago Author Posted 2 hours ago Thanks a bunch! I haven't seen that type before. Does the adjusting the nut on the end draw the jaws in tight?
fiatslug87 Posted 2 hours ago Posted 2 hours ago They self adjust and lock into place as you turn the ratchet.
llhat Posted 45 minutes ago Posted 45 minutes ago my 89 filter vertical, have always been able to use a regular strap wrench ( thin metal band) with a lever on it. you have to take small bites and position the handle in the 'right' place to apply pressure.. My "first" 4.0 filter in November 1990 on a cherokee... brand new, few thousand miles.. changed oil (early) just before a trip the following day to Hatteras Island I 'slipped' and the wrench i was using hit the distributor cap... OOPS... was lucky to have some really good contacts at local NAPA.. one fellow was in the store after hours restocking shelves.. He let me in and put a cap on my account.. took it home and installed.. never made 'that' mistake again on numerous oil changes ever since....
Pete M Posted 43 minutes ago Posted 43 minutes ago one time I had a filter that didn't quite fit the cap wrench and got it to work by putting a couple rubber gloves between the 2 for grip.
