Drahcir495's Build-up
Went ahead and bought the crossover bed box. I got it for $300+ dollars off a new one. I will have the topper on but I’m sure I will take it off at some time. Maybe just throwing money away, but it was a good price ->
  • Replies 602
Look at the size of this beetle 😳 ->
Never seen anything like that. Welcome to northern Florida. He was so strong that I couldn’t pick him up by the sides. Had to let him crawl up onto me to get a picture
I am definitely not a carpenter. Bought 5 2x3’s to hang the Napa cabinets up in the new garage. Only able to get 5 correct-sh pieces that should have been 10. The last cabinet will have to wait until I get back to Home Depot.
They are a bit higher that I would have liked, but couldn’t go back after getting it up ->
The electric is getting put in this week, so I hope to get the XJ up here first. ( Some time in August ) Then maybe have the Comanche painted down there - if I have any money left to do that?
7/14 Got them all hung and my storage bins in place (this time I didn’t fall backwards off my chair holding the cabinet) Good news, I only had to make 2 cuts->
  • 3 weeks later...
The garage has electricity :beerbang:. Wall pack on the front ->
Coach light by side door ->
Five over head led lights - 4 inside ->IMG_1028.jpeg.68b6cdd8c479f38ab0b7b88e34c46c9c.jpeg
And one over the work bench->
And 100 amp service and six outlets on two different circuits. Only thing left is the driveway getting done the 18th.
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
The hight of the Napa boxes unintentionally worked out. They are just tall enough to fit metal shelving underneath it. I had two Husky pegboards that I mounted to the back to hold my pegboard bins. The boards are just a few inches wider than the shelf, but you can’t tell when it’s set in place ->IMG_1023.jpeg.6ccab32616ea71d4c89e8728427df2df.jpeg
Then I went to find a spot for the CJ hard doors to hang. It had to be stout to hold the weight. Used a section of 2x6” wood painted silver and used 4 angle brackets held up with 4 screws each. Drilled the hanger in with several screws to secure it ->
It sits around 5” off the floor. If ever did fall it wouldn’t have far to fall.
  • 5 weeks later...
  • 1 month later...
Still no MJ. The guy at the Jeep place said he was going to start working on the Jeep this week. Riiiggght - going to be three years in April. All I really need him to do is replace the door pins on the sagging drivers door of the XJ. I can’t drive it because it’s almost impossible to shut. As soon as Lisa gets her stuff out of the garage  I can bring the Jeeps home. Meanwhile - put up my bikes on holders that allows to bikes to  swing out to the sides saving space ->
Then I hung up my fishing rod and new ladder->
Finally able to hang up the Rubbermaid fast track system->
  • 3 weeks later...
The paperwork is signed. My divorce is over - just need the courts to sign off on it. I got 50/50 custody - no alimony and no more "I'm taking my son to Wisconsin" threats. Can't take my home either - (I bought the place while I was still married, so it could have been a joint asset). And all the jeeps are mine :beerbang:. I have to go pick up the XJ here asap. Just want him to put the door pins in and I will get it home. He said he is on it:popcorn:.  If it makes the 4+ hours drive, I will use my AAA membership to get the Comanche towed with the one time 200-mile one time tow. I can't imagine how much that would be otherwise.
Bored and no real MJ news. So while Trey was playing with the kids in the neighborhood, This meant me time in the shop. Sooo, I hung another Jeep CJ front grill in the shop. I learned a lot from hanging the first grill ->
I will be putting emergency flashers in my Jeep. They are ETD (Extreme Tactical Dynamics). I drilled out 1” holes into the tail lights to secure the strobe into the taillights. I have it in my Cherokee, as my son loves them. Getting started ->
Made progress -
I used this stuff to seal the taillight cover back on the housing (I can't recall the stuff I used), but I hopefully can remember what is called and update this post ->
Strip-calk?
And the results->
TBC
  • 1 month later...
  • 4 weeks later...
