So it seems these pressure switches for the 2.5 power steering are just non existent anymore. Mines blowing fluid out the connector so its totally done.  Would like to find a replacement but there is nothing out there. Anyone have a workaround or am I just going to have the plug it?
I’m looking for one too. I’m retrofitting power steering to my 87 2.5. Is it a simple switch to ground? I’ve considered using a switch from a later non Renix 2.5 and splicing in a new connector. I’m not sure that the operating pressures are the same though.
10 minutes ago, llhat said:
educate a non-2.5 owner... what does this switch 'do'...
it does two things, increases the amount of fuel the engine takes and disengages the compressor.
Just found this thread. I’ve had PS for a while with no pressure switch. I was thinking this would be an easy part to come by, but it sounds like no?
Is the problem that no one makes the switch with the correct thread/pressure range? These are a pretty basic switch otherwise.
I’ve been running my PS with no switch and no problems, but now that I have A/C, seems like it could be a good safety feature to have.
Fun fact. The pressure from this switch will tell the ECU to cycle off the AC for extra power to power the Ps.
