neohic Posted 5 hours ago Posted 5 hours ago Has anyone added an oil cooler to their 4.0? It has been hot in Colorado. I noticed today that my oil temperature gauge (aftermarket) was reading 190°+ today. Ambient air temperature was around 100° and the coolant temperature gauge (factory) was bouncing between just under and just over 210° while under load going uphill for a few miles. I’m wondering if anyone here has had ran one, either an adapter or tapped into the block elsewhere, with good results on lowering their overall running temperatures. Thanks, gang!
89 MJ Posted 4 hours ago Posted 4 hours ago Hmmmm, if there is an oil filter relocation kit, I think I’d do that and then the oil cooler in series with the remote filter. I’m curious about this now too.
neohic Posted 3 hours ago Author Posted 3 hours ago 1 hour ago, 89 MJ said: Hmmmm, if there is an oil filter relocation kit, I think I’d do that and then the oil cooler in series with the remote filter. I’m curious about this now too. I was looking into adapter kits that also relocate the filter. Mine is a bit harder to get to now that the axle is closer to the frame. Not sure where I’d put a filter, but I think I could find a spot if the benefits are worth it.
Pete M Posted 3 hours ago Posted 3 hours ago what temperature is it supposed to be at? no sense in adding a cooler if it's unnecessary.
neohic Posted 2 hours ago Author Posted 2 hours ago 34 minutes ago, Pete M said: what temperature is it supposed to be at? no sense in adding a cooler if it's unnecessary. Right? That’s what I get for installing additional “worry circles”. I guess I’d like to see the coolant staying under 210°. It makes sense to me that keeping the oil cooler as it circulates through the engine would help the whole party keep its cool.
Pete M Posted 2 hours ago Posted 2 hours ago I assure you that the oil inside the cylinders is a LOT warmer than 210.
neohic Posted 2 hours ago Author Posted 2 hours ago 23 minutes ago, Pete M said: I assure you that the oil inside the cylinders is a LOT warmer than 210. I agree which is what was making me think that trying to lower oil temps would help with overall running temps. Now I’m wondering if trying to lower oil temps might actually harm things by not being able to cook out moisture. Hmm…
Eagle Posted 1 hour ago Posted 1 hour ago 44 minutes ago, neohic said: I agree which is what was making me think that trying to lower oil temps would help with overall running temps. Now I’m wondering if trying to lower oil temps might actually harm things by not being able to cook out moisture. Hmm… If the oil temperature is 190 and the coolant temperature is 210, the oil isn't adding heat to the coolant. According to this source, 190 is colder than optimum for engine oil: https://engineoiljournal.com/engine-oil-temperature-chart/ Also: https://oilspecguide.com/viscosity-grades/engine-oil-temperature-normal-range/ https://www.hotrod.com/how-to/engine-oil-temperature https://engineoiljournal.com/normal-engine-oil-temperature/
