Don't see why not.  I know I have siphoned some before just never tried to drain the tank.  Might be difficult to get 100% out cause making the hose be at the absolute lowest spot might be difficult, but seems like you could get most of it.
i wanted to do this few years ago during a fuel pump failure and dang near full of gas...
tried a piece of fuel hose ?(5/16 ID) and i could not get it down the filler neck...
for a 'test' I took a smaller piece of hard nylon tubing that was like 1/4" and it was troublesome getting it down there...
maybe doable, but not easy.
1 hour ago, 89 MJ said:
If I were doing this and it’s only half a tank, I think I would pull the fuel pump and siphon it that way.
Yep this, I tried using a syphon tube (the kind with the ball bearing at the end, I don't like sipping gas, lol) and couldn't get the end past 12"-15" from the filler tube.
From the sending unit side was easy
