TheNerfsmith Posted 13 hours ago Posted 13 hours ago Hi all, Have an interesting dilemma, I need all new rocker switches for my MJ, It's now a manual instead of automatic and will have KC's on the sportbar and for fog lights. That being said I need some switches for those and other things. Are the later style TJ/XJ switches the same size roughly. The new dash I have has the block off plates which probably can just be cut to accomodate the size, but I figured asking would be more helpful.
eaglescout526 Posted 12 hours ago Posted 12 hours ago No. The newer ones won’t fit. Probably could 3d print bezels to lock them in to the old pods.
RustyRodder Posted 5 hours ago Posted 5 hours ago best bet seems to be cutting the blockoff plates- Ive been looking at the same thing, only other options for rockers are the ones that replace the clock pod, or mount to the console.
Eagle_SX4 Posted 4 hours ago Posted 4 hours ago These switches have been used and fit in the factory slots.
ghetdjc320 Posted 3 hours ago Posted 3 hours ago The block off plates are part of the gauges cluster bezel piece. If you want to install carling size switches, you need to get the actual mounting base that goes behind the dash. I have piles of them somewhere if I can dig them out.
