carolinajeepman Posted June 2 Posted June 2 I am in need of a Throttle Valve cable for my 1986 Jeep comanche with the 2.8 V6 my cable seized and in an attempt to unseize it I broke it. OEM part number is 5300 1372 let me know if you have one you’d part with. Thanks!
aris_garage_builds Posted June 2 Posted June 2 I just stripped my 2.8l and might have an extra - let me check my parts bin today.
aris_garage_builds Posted June 2 Posted June 2 Ah mine is a manual so I only have the link that connects the pedal to the throttle, not the transmission. Apologies for the false alarm.
The86manche Posted June 9 Posted June 9 I can pull it off for you. Been trying to sell the Trans and tcase to no luck. Will likely end up tossing it, but if there's anything else you want off it let me know.
carolinajeepman Posted June 9 Author Posted June 9 That would be fantastic! Thank you! I would also be interested in the other cables, springs, cable brackets and sensors for it just for spares if mine go out.
The86manche Posted June 9 Posted June 9 So before I pull it off just wanted to show you its condition. It had been a while since i looked at this closer. The cable does move, no binding but the retaining end for the carb doesn't have the tabs anymore. And the sheathing is a little worn. I don't know if you will find one thats really in any better shape but I just wanted to point that out in case you were looking for something better.
carolinajeepman Posted June 10 Author Posted June 10 That’s fine, I should still be able to make that work still no problem. Thanks for checking though
carolinajeepman Posted June 30 Author Posted June 30 Unfortunately still looking for this. The 4x4 one is different apparently than the 2x4 which is what I need
Greenjeans Posted Tuesday at 08:15 PM Posted Tuesday at 08:15 PM Sorry I saw the picture but I’m not tracking.. is this from transmission to carb?
