Jeff Rodgers Posted Saturday at 10:18 PM Share Posted Saturday at 10:18 PM Wanting to swap a 88 4.0 engine that was matched with an automatic with a 4 speed from an 88 with 2.3. Will flywheels need changed ? Will the manual bellhousing with clutch and pressure plate bolt up to the 4.0? The 4.0 was from a 88 Cherokee and the vehicle that it is being installed in is a 88 Comanche and was already previously a manual. Link to comment Share on other sites More sharing options...
eaglescout526 Posted Saturday at 10:56 PM Share Posted Saturday at 10:56 PM 2.3? Do you mean the 2.5L? If so, the swap isnt worth your time for minimum power gain. And nothing from either engine swaps to each other so youll need a donor vehicle that has a manual to swap in. Link to comment Share on other sites More sharing options...
fiatslug87 Posted Saturday at 11:11 PM Share Posted Saturday at 11:11 PM 14 minutes ago, eaglescout526 said: the swap isnt worth your time for minimum power gain. Spoken like a multiple 2.5L owner. Link to comment Share on other sites More sharing options...
eaglescout526 Posted Saturday at 11:20 PM Share Posted Saturday at 11:20 PM 8 minutes ago, fiatslug87 said: Spoken like a multiple 2.5L owner. Haha! yup, guilty. Link to comment Share on other sites More sharing options...
89 MJ Posted Sunday at 01:20 AM Share Posted Sunday at 01:20 AM You’ll need the trans from the 4.0 Jeep too. Bellhousing was different between the 2.5 and 4.0. Though if you aren’t happy with the power of the 2.5, I think you’ll be disappointed with the 4.0 after doing all of that work. Link to comment Share on other sites More sharing options...
Eagle Posted 1 hour ago Share Posted 1 hour ago On 5/23/2026 at 9:20 PM, 89 MJ said: Though if you aren’t happy with the power of the 2.5, I think you’ll be disappointed with the 4.0 after doing all of that work. WHAAAAAAAAT ????? The difference is VERY noticeable. Link to comment Share on other sites More sharing options...
89 MJ Posted 1 hour ago Share Posted 1 hour ago 1 minute ago, Eagle said: WHAAAAAAAAT ????? The difference is VERY noticeable. Didn’t say that the difference wasn’t noticeable. I am saying that the effort of swapping the engine, trans, driveshafts, and engine wiring is a ton of work when there are other engines you can swap in for similar amounts of work. Link to comment Share on other sites More sharing options...
