Inteas Posted April 15 Posted April 15 Trying to remove the bench seat in my 88 Comanche and I've gotten every other nut off but this one on the drivers side nearest to the gear shifter. I've tried an extractor socket set as well as trying to hammer on a smaller 6 point socket but no luck on either. How would you guys go about removing it?
Gjeep Posted April 15 Posted April 15 I wouldn't try to get the nut off. It's done. I'd remove the stud entirely as it is just threaded into the floorboard (nut will come with it). Worse comes to worse, cut at the seat bracket then drill it out. And replace the stud (or use a bolt instead).
Smash6 Posted April 16 Posted April 16 Soak it in PB Blaster. Give it a day and soak it again. Use a wire brush and clean that nut and stud up. Then see how the nut looks. It looks like you have a vinyl floor, so be careful with using heat. Using the wax trick (google it) may work out for you and doesn't require as much heat as turning it red hot with a torch. Good luck!
Warthog Posted April 16 Posted April 16 Second the pb blaster and soaking! That crayon wax thing actually works on some things. Heat it up and let the crayon melt into it. As it cools it sucks the crayon wax into the threads. Old timers used to use that trick all the time. I’ve always had good luck with pb blaster tho.
89 MJ Posted April 16 Posted April 16 I think that nut will round off as soon as you try to turn it. I’d try to use an air hammer to split it and then peel the nut away from the stud.
