Thorwon Posted 6 hours ago Share Posted 6 hours ago I've built a 4.6L short rod stroker. I used a 1988 Comanche block, the light crankshaft and rods from a 4.2L. SPEED PRO Hyper H802CP40 pistons. The camshaft is a Crane Cam H-260-2, .456 intake .484 exhaust. And a 7120 head. I put a new Dorman 594-018 Harmonic Balancer on it. It starts and runs great, but at about 2500 RPM there's a vibration and the higher the RPM the worse it gets. Idling it's as smooth as it should be. Everything I can think of is right. Anyone have any ideas what it could be? Link to comment Share on other sites More sharing options...
ratrapp Posted 4 hours ago Share Posted 4 hours ago did you have the rotating assembly balanced?i bought a stroker kit once that said it was balanced and ready to go.it was not and it had to come back out again and taken to a machine shop to be balanced properly. Link to comment Share on other sites More sharing options...
Thorwon Posted 4 hours ago Author Share Posted 4 hours ago The crankshaft was not spin balanced but all the other components were balanced. I checked every thing. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted 3 hours ago Share Posted 3 hours ago Does the vibration happen when your driving or when parked and just revving the engine? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted 2 hours ago Share Posted 2 hours ago How may counterweights on the crank? I’m assuming you’re positive this is an engine vibe and not a tranny, flywheel or drivetrain vibe? Link to comment Share on other sites More sharing options...
Thorwon Posted 2 hours ago Author Share Posted 2 hours ago Yes it makes it when parked and revving the engine. It's the non weighted crank. I've always just called it the light weight crank. I am positive the vibration get bad as the RPM goes up. Question for ya'll. I'm running a AW4 behind the 4.6, can anyone tell me what the pilot hole in the rear of the crankshaft is? I never checked to make sure the torque converter fit the crank. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted 53 minutes ago Share Posted 53 minutes ago 1 hour ago, Thorwon said: It's the non weighted crank. I've always just called it the light weight crank. As far as I know there is not a non weighted crank shaft it should have either 12 or 4 counter weights. Do you have any pics of the crankshaft you installed in you motor? Link to comment Share on other sites More sharing options...
