Roger Slater Posted 10 hours ago Share Posted 10 hours ago My 1986 Comanche 2.5 is gradually losing power, no where near the performance when it was new. It now is very sluggish to the point that 5th gear is rarely usable Engine still sounds perfect, no oil burning and excellent oil pressure. Catalytic was removed when new. Air cleaner is new. Total miles now 110,000. Is this normal Behaviour or is there a specific known cause, valve springs perhaps?? Thanks Roger Link to comment Share on other sites More sharing options...
89 MJ Posted 9 hours ago Share Posted 9 hours ago I'd start with a compression test. Has the rear axle ratio been changed? How does it run when it is cold compared to when it is up to temperature? Link to comment Share on other sites More sharing options...
Roger Slater Posted 8 hours ago Author Share Posted 8 hours ago Compression test, good idea. Axle ratios are original. Starts and runs smoothly, hot of cold. Idles at 750 RPM. It simply could not pull the skin off a race pudding. Thanks for suggestion. Link to comment Share on other sites More sharing options...
hgeranium Posted 6 hours ago Share Posted 6 hours ago Fuel pressure is ok? Link to comment Share on other sites More sharing options...
pizzaman09 Posted 3 hours ago Share Posted 3 hours ago What's the spark plug condition? Link to comment Share on other sites More sharing options...
Roger Slater Posted 1 hour ago Author Share Posted 1 hour ago 4 hours ago, hgeranium said: Fuel pressure is ok? Dealer checked it at 25 psi last week Link to comment Share on other sites More sharing options...
hgeranium Posted 1 hour ago Share Posted 1 hour ago Just now, Roger Slater said: Dealer checked it at 25 psi last week That’s quite low. You’re looking at about 31psi at idle Link to comment Share on other sites More sharing options...
Roger Slater Posted 1 hour ago Author Share Posted 1 hour ago 2 hours ago, pizzaman09 said: What's the spark plug condition? Clean and properly gapped but will replace them shortly. Link to comment Share on other sites More sharing options...
Roger Slater Posted 1 hour ago Author Share Posted 1 hour ago 3 minutes ago, hgeranium said: That’s quite low. You’re looking at about 31psi at idle Dealer checked Pressure at 2500 RPM, said it was higher at idle but did nor record the number, Link to comment Share on other sites More sharing options...
hgeranium Posted 1 hour ago Share Posted 1 hour ago Just now, Roger Slater said: Dealer checked Pressure at 2500 RPM, said it was higher at idle but did nor record the number, It could be worth checking out the fuel pump or fuel pressure regulator in that case Link to comment Share on other sites More sharing options...
eaglescout526 Posted 1 hour ago Share Posted 1 hour ago 12 minutes ago, hgeranium said: That’s quite low. You’re looking at about 31psi at idle Hold on there. That’s for 4.0Ls. 2.5Ls need to have 15psi at the throttle body. Any higher and it would run rich and bypass the regulator. Or tear through the regulator. I had a failing fuel pump do something similar. I’d drive around just fine for a bit, but until everything warmed up is when issues would start. Shutting off and repriming the pump helped but it was an issue I didn’t want to constantly fight with. Link to comment Share on other sites More sharing options...
hgeranium Posted 1 hour ago Share Posted 1 hour ago Just now, eaglescout526 said: Hold on there. That’s for 4.0Ls. 2.5Ls need to have 15psi at the throttle body. Any higher and it would run rich and bypass the regulator. Or tear through the regulator. I had a failing fuel pump do something similar. I’d drive around just fine for a bit, but until everything warmed up is when issues would start. Shutting off and repriming the pump helped but it was an issue I didn’t want to constantly fight with. Ahh very good catch. I totally forgot it was a 2.5. My bad! Link to comment Share on other sites More sharing options...
