Gradual power loss
My 1986 Comanche 2.5 is gradually losing power, no where near the performance when it was new.  It now is very sluggish to the point that 5th gear is rarely usable Engine still sounds perfect, no oil burning and excellent oil pressure.   Catalytic was removed when new.  Air cleaner is new.   Total miles now 110,000.  Is this normal Behaviour or is there a specific known cause, valve springs perhaps??
Thanks
Roger
Just now, Roger Slater said:
Dealer checked Pressure at 2500 RPM, said it was higher at idle but did nor record the number,
It could be worth checking out the fuel pump or fuel pressure regulator in that case
12 minutes ago, hgeranium said:
That’s quite low. You’re looking at about 31psi at idle
Hold on there. That’s for 4.0Ls. 2.5Ls need to have 15psi at the throttle body.  Any higher and it would run rich and bypass the regulator. Or tear through the regulator.
I had a failing fuel pump do something similar. I’d drive around just fine for a bit, but until everything warmed up is when issues would start. Shutting off and repriming the pump helped but it was an issue I didn’t want to constantly fight with.
Ahh very good catch. I totally forgot it was a 2.5. My bad!
