derf Posted January 17 Posted January 17 If you didn't notice it, I picked up a short bed 1987 MJ a couple of months back. Turns out it is a factory Comanche Chief. My CJ project is getting close to done and I'll have room in the garage for my next project. I want to do this one before I get back to my truggy. Plans for this one are straightforward. Renix 4.0 from my parts truck AX15 from an unknown donor Atlas II - 4.3:1 low range Axles from a 70s F150. ~5" long arm lift front with SOA in the rear 35" tires on 15" wheels I'm in the parts accumulation mode right now. First up will be the axles. I currently have the axles. The front high pinion Dana 44 is a drum brake axle. I'm starting with Reid high steer knuckles that will let me build up stock disc brakes. The rear 9" housing and brakes will stay mostly stock. But I'm going to do 35 spline shafts as long as I'm doing the regear and locker. Both will get 4.56 gears and ARB air lockers. I have a truss for the front brackets and some anti-wrap spring perches for the rear. I already have some bushwhacker flares to help make room for the tires and provide some coverage for the wider axles. I also have a die on order for my tubing bender. The biggest my bender can handle is 2-1/2" tube but I'm going to use it to make a roll bar that almost looks stock. I'm thinking it'll get an ARB bull bar for the front and some kind of heavy duty rear bumper. I'll make some rock sliders and custom skid plates. I have two short beds, both with various damage. Between them I'll be able to build one whole bed. The paint on the base truck is beyond shot and the rest of the parts won't match so it'll get a full strip and paint. I'm leaning towards a dark blue paint job with cordovan interior. Best part is that I can get the chief stickers. Most likely they'll be light grey. It's likely going to take a while to get all the parts (budget constraints and all) and get the work done. But it should be pretty cool when it's done.
derf Posted January 24 Author Posted January 24 The first few parts are filtering in. Got the knuckles and caliper brackets in. The spindles and hub/rotors are here too but no.pictures.
89 MJ Posted January 25 Posted January 25 I’m looking forward to this build. Seems like a good combination between a trail rig and a daily drivable truck.
derf Posted January 29 Author Posted January 29 Full knuckle, hub, and rotor. I'm not going to assemble it all until the axle goes together. Brake parts are on the way. It'll take me a bit for the budget to be ready for the gears, lockers and shafts. Got the relay box wired up and ready for installation. Set up for the lights, lockers, and compressor I'm going to install. This is the box I used. You can get it prewired but I wanted to customize it a little. https://www.amazon.com/gp/aw/d/B07MR64XK1?psc=1&ref=ppx_pop_mob_b_asin_title&th=1
derf Posted April 3 Author Posted April 3 The tax return showed up today. All the parts to regear the axles going under this Chief.
derf Posted April 3 Author Posted April 3 And as long as I'm remembering, here are the donor axles...
derf Posted April 11 Author Posted April 11 Not much work on the actual truck today. But I did rearrange a bunch of stuff to get ready for when the CJ is done in a week or three. The long bed I picked up at the junkyard got moved onto the truck that it's destined for. It's sitting on the axles that are for the truggy with lift springs in the front and an SOA on a Dana 80 in the rear right now. But the key is that it's not blocking my gate anymore. Then I moved the parts donor grey MJ over to the gate so I can pull it around and strip it. Then the chief is behind it. Ready to roll in to the garage when the parts donor is done.
derf Posted May 17 Author Posted May 17 Now that the CJ is mostly mobile, I'm going to get started on this project in earnest. First step is to strip the silver donor for parts. I'm keeping the engine and wiring, as well as some of the interior and at least part of the bed. Some of the good metal is going to @aris_garage_builds for the 4.0 swap. The donor is in the garage and I've started the tear down process.
derf Posted August 8 Author Posted August 8 No real progress this summer. It's been too hot. The silver donor has been mostly processed. It's back in the yard for storage, many parts sitting in tubs in the cab, waiting. If it wver cools down, I'll get the garage cleaned and organized. First steps will be to take care of the big pile of axle parts. I'm going to strip them down to nothing. Then build them up from the ground up. New everything. Gears, lockers, high steer knuckles, truss with XJ/MJ mounting points for the long arms to bolt to. After that, the AX15 gets torn down and rebuilt. Once those are done and the parts pile is more manageable, the truck will get wheeled into the shop and any body work will begin.
derf Posted August 9 Author Posted August 9 AX15 to rebuild. Two Renix 4.0s to choose from. Ready to start the first real phase of the build.
ghetdjc320 Posted August 10 Posted August 10 Looking great! Were you planning to do any upgrades to the AX15?
derf Posted August 10 Author Posted August 10 17 minutes ago, ghetdjc320 said: Looking great! Were you planning to do any upgrades to the AX15? Probably a short throw shifter. And an external slave at least.
derf Posted Sunday at 08:34 PM Author Posted Sunday at 08:34 PM Now that my other projects are out of the way, it's time to use up the table full of parts. Building the axles is the first step in actually getting this project built. I will also be tearing down the engines in the background to build 1 good one. If anyone is looking for Renix parts, I'll have extra.
derf Posted Sunday at 11:00 PM Author Posted Sunday at 11:00 PM Yep. Out of a 70s F150. With a bunch of convoluted hydro assist steering going to the scrap yard.
derf Posted Sunday at 11:31 PM Author Posted Sunday at 11:31 PM The radius arm nubs come off pretty easily. Just need to grind the remaining weld down. And cut off the track bar bracket. It's getting a full truss with XJ/MJ mounts.
derf Posted Sunday at 11:54 PM Author Posted Sunday at 11:54 PM Diff oil in the front was way low. And there's a film of grit. Probably past due for a rebuild. It is 50 years old after all. It's a good thing I was already planning on doing a complete rebuild already when I regear. Every last removable part will be replaced.
derf Posted 22 hours ago Author Posted 22 hours ago The patient is on the table, doctor. Everything from the ball joints out will be replaced. I have new Reid high steer knuckles and all the hardware I need to do a disc brake swap. First step will be to finish removing bits and grinding the slag off the tubes before I can weld on the truss and brackets. Then the build up will start.
Smokeyyank Posted 14 hours ago Posted 14 hours ago What truss did you go with? You going to run the ford or cheby discs?
derf Posted 11 hours ago Author Posted 11 hours ago 2 hours ago, Smokeyyank said: What truss did you go with? You going to run the ford or cheby discs? I went with Next Venture Motorsports out of Grand Junction. I'm going to stick with all Ford parts. It just makes life easier. And it keeps the 5 on 5½" bolt pattern.
