NP 242 - FOUND!!
neohic
Good folks of CC-
I’m looking for a NP 242 transfer case. What’s everybody got sitting around? Obviously the closer to central Colorado the better, but I will be driving up to Minnesota in December if anybody is along the way. :beerchug:
Edit: Input spline not a huge deal, but ideally 21. I can swap inputs between my 231 if I need to.
you should specify input spline count :L:
242s were still in use in some KJs. :D not sure what all differences there might be though that might negate it as an option.   :dunno:
WJ and KJ 242's don't have a provision for a speedometer gear. The output shaft has no teeth for the gear and the tail housing hasn't been machined to accept a speedometer gear. I think that is the only major difference.
First post updated. Spline count isn’t a deal breaker but I definitely need a speedometer gear housing.
7 minutes ago, Eagle_SX4 said:
Check car-part.com and search for 1988 Jeep Cherokee Transfer case and select the 242. Looks like there is a one in Colorado. High milage though.
I saw that one. Very high miles for the price. There is the convenience factor if I can’t find another though.
I'll be on the lookout. Did you check with timbukthree? I know they are moving but I saw they are clearing out a bunch of stuff. I had chatted with Neal a few months ago about building my 242HD but the SYE was the issue.  Not sure if he has any.
  • neohic changed the title to NP 242 - FOUND!!
