Is this the factory optional front winch???
TNT
The fairlead looks to low for it to be the factory setup.
It used a special 6000-lb Ramsey winch that was a little different so it could be oriented the right way to fit.
Here is the install directions: http://www.ramseypdfs.com/owners_sea...s/295153-D.pdf
Parts list from my FSM (Ver. 8J, Figure 13-1000)
Item/Item#/quantity/description
1 8350 1124 1 EXTENSION, Rail
2 8350 1125 1 EXTENSION, Rail
3 8350 1126 4 BRACKET, Angle
4 8350 1127 2 BRACKET, Angle
5 8350 1128 1 RETAINER, Rail (Not Serv.)
6 8350 1129 1 BRACKET, Winch Mounting
7 8350 1130 1 SHIELD, Bumper
8 8350 1131 1 SHIELD, Bumper
9 8350 1132 1 STRAP, Inner
10 8350 1133 1 STRAP, Inner
11 8350 1134 1 STRAP, Outer
12 8350 1135 1 STRAP, Outer
13 8350 1149 6 BOLT ***
14 BOLT S012 1887 4 (1987-89)
14 BOLT J018 0020 4 (1990)
15 J018 0079 10 BOLT ***
16 J999 8112 2 BOLT, (Not Serv.)
17 8350 1150 6 SCREW
18 J012 0361 6 NUT
19 J012 0375 10 NUT
20 J012 0376 6 NUT
21 S012 0378 2 NUT
22 S012 0217 6 WASHER, Lock
23 J012 0380 10 WASHER, Lock
24 J012 0392 2 WASHER, Plain
25 J012 0214 6 WASHER, Lock
26 J012 0393 2 WASHER, Plain
27 S012 0384 2 WASHER, Lock
28 8350 1136 4 NUT, U-Type
29 8350 2247 1 GUIDE, Solid Cable
And no, they are no longer available from Ramsey or directly from Jeep....
Thats what one looks like...
I have seen them in the accsesory catalog and the parts catalog with all the required parts before but never saw a pic of one.
Your pic shows the factory filler panels and everything. I'll have to check my e-fiche and see if it still shows it.
How much did that cost as a factory option? I have seen it in my owners manual, but I have never actually seen one on a Jeep. I figured they would have been more common, I can't imagine buying a brand new MJ and NOT getting the factory winch put on.
I have never seen a factory hidden winch in the U.S. -- ever.
When I visit my wife's family in Santiago, Chile -- they're everywhere. Mostly on Cherokees, but I did see one Comanche a couple of years ago that had the winch.
maybe Ramsey found a market outside the US at that time?
They're fairly common up here.
