Cruise Control Max Speed
Been driving corner to corner in Pennsylvania today, using the cruise control we've discovered the max speed it wants to set to is about 73-74 mph.  If we accelerate beyond that and try to set it, it will simply coast down to that speed before engaging.  Any idea why this might be?  It's not a big problem as the fastest speed limits are 70 mph, but the truck can easily cruise faster.
Side point, I have an REM and reading out TPS shows that the cruise can manage to use up to about 45 on the TPS signal.  WOT on mine tends to read 90 so that's a lot of throttle it will not use.
I'll have to check the vacuum connections, the truck seems to hold good vacuum according to my REM.  It does seem like the servo shtbe able to pull more than it does.  Sometimes it loses speed on hills because the servo loses too much vacuum due to the engine being at a fairly open throttle level.
^^^   and that is where the 'football' under the front bumper 'kicks' in with vacuum supply....  if low vacuum your hvac would divert to the defrost ducts
noted also there is an 'adjustment' on the control box (multiple),
"A" is the centering adjustment
"B" is low speed adjustment
"C" is sensitivity  (located on opposite side of box from A and B
one of those should help I'd think....  suggested to make fine incremental adjustments
I'll have to play with it, I did a lot of adjustments when I first installed the cruise control and it operates nicely otherwise.
I did make one modification to the vacuum system on the truck to make it work better, I put a one way vacuum valve in the line connecting to the intake manifold.  It must leak down somewhere.
Check the dump valve above the brake pedal, make sure that is good and sealed with the brake pedal in the neutral position. I literally test it by blowing into the dump valve. You want no air to get by, I can see it still letting some air pass when at those high of speeds and releasing it just a small amount.
I have had my cruise set to almost pegged on the dash (speedo gear is off but the truck can’t tell the difference) and it’s held it just fine. I’d say there’s an issue with the cruise control system itself. I’ve had to reach down and gently tap my control module a few times cause it would do the same thing, set at 55, then decelerate slowly to 50, then 45, then keep speed at like, 40. Tapping the module makes it go right back to the speed requested. Dunno why exactly but I’m too lazy to pull the module out while it’s still working so I shall continue to give it the occasional percussive maintenance.
I'll have to check this out.  I've been busy lately and this isn't at the top of my priorities.  Maybe that would explain why I have minimal brake boost too.
Interesting
