garyweb3 Posted August 4, 2025 Share Posted August 4, 2025 According to the TBI manual the voltage reading at terminals B and C should be 5v at WOT. It doesn't say what it should read with the throttle closed but I assume less than 5v. My TPS doesn't vary at all always reads 5v no matter the position of the throttle. This is a new TPS because the previous one read the same as this one, no difference always 5v and I was advised it was bad. This doesn't sound right because how does the ECM know how far the throttle is open. Also checked between terminals A and B and read 4.85v at WOT. That does vary when the throttle is opened even if it's higher than the manual specifies max of 4.6-4.7v. What could be wrong? Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 4, 2025 Share Posted August 4, 2025 Make sure the lever on the TPS is under the post on the TB. And follow Cruiser’s TPS tip. Link to comment Share on other sites More sharing options...
garyweb3 Posted August 4, 2025 Author Share Posted August 4, 2025 I have the TPS removed and testing it like that. Manually moving the lever. Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 4, 2025 Share Posted August 4, 2025 What engine/year do you have? Put your truck’s info in your signature. Link to comment Share on other sites More sharing options...
garyweb3 Posted August 4, 2025 Author Share Posted August 4, 2025 1 minute ago, fiatslug87 said: What engine/year do you have? Put your truck’s info in your signature. 1987 Comanche w/2.5L. Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 5, 2025 Share Posted August 5, 2025 I think your reading the voltage supply to the sensor. Good it’s getting 5v but the voltage from A and B is what you’re after. WOT between the two should be between 4.62v and 4.65v. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted August 5, 2025 Share Posted August 5, 2025 The TPS will move farther than the throttle (both opened and closed) which is why adjusting it is critical. The max voltage with the TPS off the throttle body will be higher than when it is installed adjusted properly and the throttle maxed out. Link to comment Share on other sites More sharing options...
garyweb3 Posted August 5, 2025 Author Share Posted August 5, 2025 Ok but why doesn't it vary at all? It's 5v at closed throttle and open throttle no change from one or the other. How will the ECM know what position the throttle is? Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 5, 2025 Share Posted August 5, 2025 46 minutes ago, garyweb3 said: Ok but why doesn't it vary at all? It's 5v at closed throttle and open throttle no change from one or the other. How will the ECM know what position the throttle is? That’s because that’s supply voltage to the sensor. If your probing B and C you should see 5v constant regardless of the position. A and B is the input voltage to the ECU so it does know what it’s position is. Link to comment Share on other sites More sharing options...
garyweb3 Posted August 5, 2025 Author Share Posted August 5, 2025 Since that does vary the TPS should be good? Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 5, 2025 Share Posted August 5, 2025 15 minutes ago, garyweb3 said: Since that does vary the TPS should be good? Yes. If it sweeps clearly with no hiccups, it’s good. Link to comment Share on other sites More sharing options...
garyweb3 Posted August 6, 2025 Author Share Posted August 6, 2025 Thanks for the information. It's much clearer and makes more sense than the TBI manual. Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 6, 2025 Share Posted August 6, 2025 23 minutes ago, garyweb3 said: Thanks for the information. It's much clearer and makes more sense than the TBI manual. Really? I thought the TBI manual made sense…to me at least. Link to comment Share on other sites More sharing options...
garyweb3 Posted August 6, 2025 Author Share Posted August 6, 2025 It does but it didn't explain the voltages that I should get like you did. It doesn't specify that 5v will be seen at the full range of movement of the throttle. I thought that measurement was what the ECM see's to varify the throttle position. Link to comment Share on other sites More sharing options...
llhat Posted August 6, 2025 Share Posted August 6, 2025 go back and review what was posted above. there's a lot of explanation there.... here's another link so you don't have to scroll. Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 6, 2025 Share Posted August 6, 2025 2 hours ago, garyweb3 said: It does but it didn't explain the voltages that I should get like you did. It doesn't specify that 5v will be seen at the full range of movement of the throttle. I thought that measurement was what the ECM see's to varify the throttle position. Ahhh. Yeah I know what you’re talking about now. Link to comment Share on other sites More sharing options...
