JimManche17 Posted July 18, 2025 Share Posted July 18, 2025 I am looking at options for rear trailer hitches as I need one to tow my bass boat around. I see they don't make any aftermarket ones for our trucks. What have you guys done I see some universal kits you can weld up has anyone done that before? Link to comment Share on other sites More sharing options...
89 MJ Posted July 18, 2025 Share Posted July 18, 2025 @krustyballer16 makes them. Check out his posts in the Vendors section. Link to comment Share on other sites More sharing options...
Pete M Posted July 18, 2025 Share Posted July 18, 2025 if you can weld, you can buy his side brackets separate from a whole unit and grab a hitch from an Excursion from a local junkyard. I did that to the 88 I was working on. I used the excursion after failing to find a single pickup that had a wide enough hitch (they all seem to go between the inner frame walls rather than the MJ's outside-to-outside). Link to comment Share on other sites More sharing options...
SCJ Steve Posted July 27, 2025 Share Posted July 27, 2025 I made my own. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted August 3, 2025 Share Posted August 3, 2025 The one from Krusty is well made and worth the price. You'll need to paint it, but that's no big deal. Link to comment Share on other sites More sharing options...
jeff351 Posted August 3, 2025 Share Posted August 3, 2025 +1 for Krustyballers hitch. Link to comment Share on other sites More sharing options...
TX_Heat Posted August 4, 2025 Share Posted August 4, 2025 If you have the FEY/Westin bumper you can look for a Reese 37042 universal receiver hitch. I was able to find one locally for $40 a few weeks back and got it mounted recently. Link to comment Share on other sites More sharing options...
pizzaman09 Posted August 4, 2025 Share Posted August 4, 2025 10 hours ago, TX_Heat said: If you have the FEY/Westin bumper you can look for a Reese 37042 universal receiver hitch. I was able to find one locally for $40 a few weeks back and got it mounted recently. This is interesting. I have a Fey Westin bumper and just mount a ball to the bumper, however it results in a very high hitch point. Link to comment Share on other sites More sharing options...
TX_Heat Posted August 6, 2025 Share Posted August 6, 2025 On 8/4/2025 at 7:00 AM, pizzaman09 said: This is interesting. I have a Fey Westin bumper and just mount a ball to the bumper, however it results in a very high hitch point. I saw the combo mentioned here on the forum and usually a link to this post on an XJ forum. Link to comment Share on other sites More sharing options...
