Egr and vacuum line trouble
Can you post a picture of the loose vacuum lines that you've got? Maybe a picture of the engine bay from the front left corner too? Just so we can look and see if anything looks out of place.
On another note, to get it to run, you just need air, fuel, spark, and compression. Plug your vacuum leaks in the intake and carb, verify that you're getting those 4 things and it should run. Then we can focus on getting it running properly.
Edited by 89 MJ
Clarifying what I said
If you just want it to run, plug all loose lines going to the carb or intake manifold as they will be vacuum leaks.  Alternativly, you can start plugging them back in where they belong.  The goal is to eliminate as many vacuum leaks as possible as that will give it the best chance of running.
4000?    yikes,  this with vacuum lines plugged?
will it run 'off' of the cleaner?  i think i see fuel in the clear filter...
far from expert, but the choke is still engaged on the weber,  this activates a 'fast idle cam'
which opens the throttle plates at the base of the carburetor, increasing idle speed.
ensure the fast idle cam disengaged and basic visuals for vacuum leaks.
good luck
