These rotors look okay?
26 minutes ago, pizzaman09 said:
That's fine.  They must make the disk for two different bolt pattern wheels.  The load transfer ina brake disk should really come from the clamping of the disk between the wheel and hub.
Cool, appreciate the info. Yes it's for a 5x5.5 and 6x5.5.
3 hours ago, derf said:
No.  That's not Okay.  I would send them back.
:yeahthat: But… they can’t drill a 6 lug and 5 lug pattern without interference if the diameter is close enough. Proper conversion rotors would be best and should only have the pattern you need. But these rotor will work in a pinch
Appreciate the info. Tricky part is these are the explorer rotors with an internal parking brake so the hat is the issue. After looking at them more they have to go back regardless because the new lug size is wrong. Ordered 1/2 and got 5/8. Played around with a wheel spacer I randomly had and there is going to be one that overlaps. So may just go with Eldorado calipers and 6x5.5 rotors.
do not believe the 5 lug pattern is on 5.5 circle,   if they were the centerlines of both 5 and 6 holes would be on same circle.
no, I would not 'like' the result shown above at the 2:30 o'clock position, but like others, do not think there's an effect on braking.
Just for pure kicks and giggles, checkout an Isuzu rodeo/Honda passport rear rotor from 95 up to 2003. 95-96 will be one style, 97 will be another and 98-03 will be yet another. All had a 6x5.5 patter and internal parking drum brake. Who knows if it’s anything that may fit but worth a shot :dunno:
