maddzz1 Posted January 10, 2008 Share Posted January 10, 2008 I have an oil leak around the drain plug ever since the service guy decided to use an air gun to put the plug back in. I tried putting a new plug in and it is still leaking. Can I get some high temp RV sealant and put it around the plug once its in and tight? Because the plug is already in and tight the sealant shouldnt get into the oil pan. Link to comment Share on other sites More sharing options...
Pete M Posted January 11, 2008 Share Posted January 11, 2008 I bought a couple little donut gaskets at the auto parts store. :thumbsup: Link to comment Share on other sites More sharing options...
johngus Posted January 11, 2008 Share Posted January 11, 2008 You can also go to a chain store like NAPA and get a slightly oversized replacement plug. You will need to take the old plug with you. Link to comment Share on other sites More sharing options...
maddzz1 Posted January 11, 2008 Author Share Posted January 11, 2008 The problem is every time i try something else it costs me 6 quarts of oil :mad: I will check those out thanks. The plug I used this time has a bigger(wider) top and it didnt help Link to comment Share on other sites More sharing options...
Wildman Posted January 11, 2008 Share Posted January 11, 2008 Really sounds like your "Service guy" owes you a new oil pan. Who would be stupid enough to use a air wrench on the oil plug :nuts: As Johngus wrote, they do make a over size oil plug that cuts new threads as in goes on. Your "Service guy" blew out the treads on the oil pan using his air wrench :shake: Link to comment Share on other sites More sharing options...
jtdesigns Posted January 11, 2008 Share Posted January 11, 2008 just goto the hardware store and pick you up a roll of plumbers thread tape, (white ribbon), only about a buck.. remember to wrap in the same direction as the threads.. so when you tighten the plug the tape will tighten. Link to comment Share on other sites More sharing options...
skimore11 Posted January 11, 2008 Share Posted January 11, 2008 Are you sure your oil is leaking from the plug? I thought mine was but turns out there was a pin hole in the bottom of the pan just forward of the plug. Link to comment Share on other sites More sharing options...
maddzz1 Posted January 13, 2008 Author Share Posted January 13, 2008 This happened before i got the truck so I can't do anything with the service place. I will try the donut gaskets and the pipe tape. If they don't work I will go with the new pan. Link to comment Share on other sites More sharing options...
