Archaeor Posted August 9, 2024 Share Posted August 9, 2024 '89 4.0 4x4/manual. What is this relay next to the ballast resistor? It looks melted on the bottom. I'll start the motor, it will idle just fine and then die after three to ten minutes. I've replaced the ballast resistor, same problem. Could the relay be the problem? It ran fine last winter. Also, is a vacuum hose missing on the vacuum valve below the resistor? Thanks....... Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 9, 2024 Share Posted August 9, 2024 Looks like an E-fan relay. Probably for AC. Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 9, 2024 Share Posted August 9, 2024 Yes, fan control relay and it does not look like you’re missing a vac line. That’s the EGR solenoid which has a plug on one port of the vacuum line. Link to comment Share on other sites More sharing options...
Archaeor Posted August 9, 2024 Author Share Posted August 9, 2024 Thanks for the info. So, if the fuel pump ballast resistor is good, what else would cause the engine to die? It doesn't sputter, just stops running. Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 9, 2024 Share Posted August 9, 2024 If I had a 4.0 with the ballast. I wouldn’t run it it all. Bypass it and be done with that thing. All it did was quiet down the fuel pump for the XJ. Link to comment Share on other sites More sharing options...
pizzaman09 Posted August 10, 2024 Share Posted August 10, 2024 Does is restart right a way or does it need some time to come around before it will restart? Link to comment Share on other sites More sharing options...
Archaeor Posted August 10, 2024 Author Share Posted August 10, 2024 It will restart right away, run for a few minutes then die again. I'm thinking maybe a fuel delivery problem like the fuel filter. or the pump. I also live in the mountains and have had rodents, spiders and wasps etc. live under the hood, but not for a few years since I got a couple of mousers. It ran okay last winter, and no recent sign of critters under the hood. Link to comment Share on other sites More sharing options...
jdog Posted August 10, 2024 Share Posted August 10, 2024 Hook up a fuel pressure gauge to it and watch it when it does, if it drops to zero it's a fuel issue Link to comment Share on other sites More sharing options...
