Everything posted by Archaeor
It will restart right away, run for a few minutes then die again. I'm thinking maybe a fuel delivery problem like the fuel filter. or the pump. I also live in the mountains and have had rodents, spiders and wasps etc. live under the hood, but not for a few years since I got a couple of mousers. It ran okay last winter, and no recent sign of critters under the hood.
'89 4.0 4x4/manual. What is this relay next to the ballast resistor? It looks melted on the bottom. I'll start the motor, it will idle just fine and then die after three to ten minutes. I've replaced the ballast resistor, same problem. Could the relay be the problem? It ran fine last winter. Also, is a vacuum hose missing on the vacuum valve below the resistor? Thanks.......
'89 Command-Trac Front Axle Vacuum Line
Archaeor replied to Archaeor's topic in MJ Tech: Modification and Repairs
Thanks 54bobby for letting me know it doesn't connect to anything. I did your reverse and brake fix...... tried it and it didn't work. Light is still on, oh well. I'll just disconnect it, I can tell if it's in 4WD or not just by the way it feels. Thanks Pete M for your link. I'm actually thinking about getting rid of the Comanche (too much sh*t, crap, hoses, vacuum lines, wires, sensors, etc.......) under the hood. I used to have a '57 M38A1 with a Buick 225...... easy peasy!! -
Archaeor posted a topic in MJ Tech: Modification and Repairs
Is this blue vacuum line supposed to attach to anything, or is it the "Air Vent Filter" (number 3 in the diagram)? It's located on the passenger side, near the heater blower. I found it when trying to find out why the "Part Time" light on the dash doesn't turn off when the transfer case is in 2H. All other vacuum lines from the front axle appear to be attached. Thanks, Rick -
Persistent Squirrel Problem.......
Thanks for the responses...... my Comanche sits for long periods of time without being driven, so I ordered one of these...... https://www.amazon.com/Loraffe-Ultrasonic-Deterrent-Vehicle-Protection/dp/B07N2NFX28/ref=sr_1_2_sspa?ie=UTF8&qid=1549425874&sr=8-2-spons&keywords=rodent+deterrent&psc=1 -
Not a bad idea, I may try that. Unfortunately, I live in the mountains, there are at least half a dozen squirrels on my property, and with my luck I'd catch a skunk....... I've got those, too. -
I went to start the Comanche the other day, no go. I popped the hood and a squirrel had made a nest on top of the battery using the insulation on the underside of the hood. It also filled every nook and cranny inside the engine compartment with hundreds of acorns!!! I've removed the nest and spent the next hour with the shop-vac getting the poop and acorns out. Luckily, it only chewed thru one little wire, which I found and repaired. Comanche is back running, but the squirrel keeps coming back daily and/or nightly and leaving more "gifts" and chewing off more insulation. Anybody have any good ideas on how to keep the squirrel out of my truck (aside from shooting or poisoning the bastard)? Mothballs perhaps? Anybody else ever have this problem?
Won't Start, Will Start.......
Thanks, I'll give it a shot... -
'89 Renix 4.0. Yesterday morning after it snowed, I needed my 4x4 Comanche to get me to the store. It turned over but would not start. I tried for about 5 minutes until the battery started to lag. As usual, I just put it in neutral and didn't touch the gas pedal for the first few tries. Nothing. Then (being old school, I tapped the gas pedal) and still no start. Then tried turning it over with the pedal floored. Nothing. Oh well, I braved it to the store in my 2WD Tacoma. Anyway, this morning I go to start the Comanche and it starts right up, first try. This is the second time this has happened. What gives? Why won't it start for anything in the world one time, and the next time it starts right up? And I haven't done anything different.....
Alternator or Something else.... '89 Renix
The gauge used to read a solid 14 volts........ -
The truck sputtered then died. It turned over slowly a few times, but battery was dead and wouldn't start. Got a jump and made it home. Trickle-charged the battery for a few hours and now it starts, but the alternator is only putting out 9-10 volts according to dash meter. Is my alternator shot, or could it be something else like a loose wire or connection? Thanks. Rick
All Stock/Original-No Modifications 93K Miles Added Factory Brush Guard Mariposa County, CA Used Whenever 4x4 is Necessary
'89 4.0 Renix Valve Train Noise When Starting?
Well, got up up the cabin.... It's already got a Wix on it. Engine only has 93,000 original miles. Guess I'm gonna try Lucas Oil Stablizer next......... Rick -
Mine's a perfect fit. For my '89, it's two pieces. One for the dash and one for the glovebox. It comes with velcro strips to hold it in place. HTH, Rick
IMHO, these are the best! http://www.covercraft.com/us/en/dash-covers Rick
So I know there's quite a few vacuum controls behind the dash (climate control, heater, AC, etc.) I can hear them open and close when I start the truck, change heater/AC settings, etc. Here's my question: When highway driving (and sometimes city driving) I have the interior fan off, Climate Control off, Heater off, both levers to the left. Every so often, especially when cresting a hill, I hear a vacuum control move behind the glovebox. Any idea what it is? I'm puzzled..... Thanks, Rick
Thanks for the info. The MJ is up at my cabin right now, so I don't know what oil filter I'm running, but if it's a POS I'll swap it out for a Wix and see what happens. Thanks...... -
Got The Brush Guard Installed
Hi 88mjblue, not sure if they were truly a factory option, but I know of at least two just like this which were purchased in 1989 (one on a Comanche and one on a Cherokee) when the vehicle was purchased new from the dealership. Maybe an aftermarket dealer option? -
Good eye! Nope, it belongs to my neighbor...... -
@$$-cracks, Beware, too!!!!!! :laughin: -
Got this off Craigslist..... factory bumper, brush guard, tow hooks, with appropriate brackets. PITA to install (I'll be sore tomorrow), Pedestrians Beware!! J/K..... Rick
