996xj Posted April 18, 2024 Share Posted April 18, 2024 1987 Jeep Comanche 4.0L AMC, 5 Speed Manual, Floor Shift, Part-Time 4WD 7.0' Bed, D30 & D35, 120" WB Hello! My name's Bree and this is my white and blue 1987 Comanche I bought the cab from a friend a while back and planned on building a rock bouncer. Coincidentally, found the original bed (and the original owners!) on Marketplace a few months later and, of course, had to pick it up. Another couple of months went by and I found a totaled 98 XJ with 120k on the 4.0 and an AX15. The plan has since changed and is now to fully restore it with a twist. I came across one too many perfect coincidences, and the white and blue trim is just too cool. I'll be keeping the blue interior plastic, door panels, original blue bench seat, and keeping the body completely stock. As for its "guts," I'll be swapping in the dash, wiring/electronics, fuel, accessories, and drivetrain from the '98. This past weekend, I completely gutted the '98 and scrapped what I couldn't get rid of. This coming weekend, I'll modify the firewall and test-fit the drivetrain. If anyone's at all interested in the conversion, I made a dumbed-down to-do list: Preparation and Disassembly: Strip the MJ completely, including interior, drivetrain, and accessories. Use labeling, bags, and photos for organization during disassembly. Sheet Metal Work: Modify the firewall to fit the XJ components. Patch holes, resize openings for the fuse box and steering column, and seal the firewall properly. Dash Mounting: Fabricate new bolt holes and tabs for mounting the dash. Weld braces onto the firewall for upper dash mounting points and steering column support. Under Hood Accessories: Move accessories like washer bottle, ECU, cruise control, and wiring harness from XJ to MJ. Install under-hood wire harness, vacuum lines, brake lines, etc. HVAC Box: Install the HVAC box without the engine in place for easier mounting. Drivetrain Installation: Drop the drivetrain into place, check motor and transmission mounts, and measure for driveshaft compatibility. Interior Insulation: Optional. Add insulation to the interior, especially the roof, back of the cab, and floor. Wiring: Transfer and label wiring harnesses from XJ to MJ. Install bulkhead connectors, route looms, and connect various electrical components. Interior Reassembly: Install trim, console, bench seat, and other interior components. Modify A-pillar trim if necessary for a proper fit. Fuel Tank: Install a new tank without a slosh pan, use an adapter ring for the XJ fuel pump, and relocate the charcoal canister for emissions compliance This is how it's currently sitting (minus the steering column & wiring). I'd like to have a more satisfying end to my post but I'm only now getting around to prioritizing the build. I document a lot of my work on my Instagram if anyone is interested in the progress. The door label has been lost to time, but I do have the original Vehicle Building Order: The car's still under the original owner's name. After meeting him and chatting, I filed for a lost title and am getting everything signed over. Located on the Columbia between Oregon and Washington. Feel free to let me know if you've got questions or advice! I'm always open to chat about my projects Link to comment Share on other sites More sharing options...
89 MJ Posted April 18, 2024 Share Posted April 18, 2024 Nice truck! Be sure to start a build thread on it. @Pete M, this one has a build sheet. Link to comment Share on other sites More sharing options...
996xj Posted April 18, 2024 Author Share Posted April 18, 2024 2 hours ago, 89 MJ said: Nice truck! Be sure to start a build thread on it. @Pete M, this one has a build sheet. Thank you! The sheet's a bit moldy (and ripped in half), but still pretty neat. I'll probably scan it tomorrow and update my post with a clearer version of it Link to comment Share on other sites More sharing options...
89 MJ Posted April 18, 2024 Share Posted April 18, 2024 1 hour ago, 996xj said: Thank you! The sheet's a bit moldy (and ripped in half), but still pretty neat. I'll probably scan it tomorrow and update my post with a clearer version of it That would be great! CC shrinks the size of an image, so it still may not show up great. I tagged Pete because he has an email for the build sheets to be sent to so that we can figure out all of the optional equipment. I think it’s something like comancheclub@hotmail.com, but I don’t remember for sure. Link to comment Share on other sites More sharing options...
Pete M Posted April 19, 2024 Share Posted April 19, 2024 comancheclub@hotmail.com Link to comment Share on other sites More sharing options...
996xj Posted April 19, 2024 Author Share Posted April 19, 2024 17 hours ago, 89 MJ said: That would be great! CC shrinks the size of an image, so it still may not show up great. I tagged Pete because he has an email for the build sheets to be sent to so that we can figure out all of the optional equipment. I think it’s something like comancheclub@hotmail.com, but I don’t remember for sure. Oh, that's awesome! I've updated my post, but I'll go ahead and shoot him the originals too Link to comment Share on other sites More sharing options...
89 MJ Posted April 19, 2024 Share Posted April 19, 2024 49 minutes ago, 996xj said: Oh, that's awesome! I've updated my post, but I'll go ahead and shoot him the originals too Sounds like a plan! Link to comment Share on other sites More sharing options...
jdog Posted May 1, 2024 Share Posted May 1, 2024 BODY: JL62 BUILD: 02/25/87 SELLING DEALER: FALORE'S SERRAMONTE CHRYSLER COLMA, CA A6 VINYL TRIMMED BUCKET SEATS -Q8 DESCRIPTION NOT AVAILABLE ADL SKID PLATE GROUP AHL HEAVY DUTY INSULATION GROUP APB WATER FALL TWO TONE PAINT APC CENTER BAND TWO TONE PAINT BCQ MAINTENANCE FREE BATTERY CBA STRAIGHT BACK BENCH SEAT CGX RR HEAD RESTRAINTS OUTBOARD SEATING CKA CARPET DDQ 5-SPEED MANUAL TRANSMISSION ERB 4.0L I6 MPI ENGINE GAC TINTED GLASS WINDOWS GEC FRONT LEFT SIDE SLIDING WINDOW GFD REAR SLIDING WINDOW HCC DO NOT USE - SEE HCA JAY DO NOT USE - SEE JP, KA CLASSES JFH TACHOMETER JGB JHA VAR INTERMITTENT WINDSHIELD WIPERS JJA CIGAR LIGHTER LAP SHIFT INDICATOR WARNING LAMP LMA HALOGEN HEADLAMPS MBJ BLACK FRONT BUMPER MDA FRONT LICENSE PLATE BRACKET NAE CALIFORNIA EMISSIONS NFA 23 GALLON FUEL TANK PXB QXG SBA POWER STEERING SUA TILT STEERING COLUMN TBG COMPACT SPARE TIRE WJM 15X7.0 CHROME WHEELS XEA TOW HOOKS Link to comment Share on other sites More sharing options...
996xj Posted May 9, 2024 Author Share Posted May 9, 2024 On 5/1/2024 at 7:56 AM, jdog said: BODY: JL62 BUILD: 02/25/87 SELLING DEALER: FALORE'S SERRAMONTE CHRYSLER COLMA, CA A6 VINYL TRIMMED BUCKET SEATS -Q8 DESCRIPTION NOT AVAILABLE ADL SKID PLATE GROUP AHL HEAVY DUTY INSULATION GROUP APB WATER FALL TWO TONE PAINT APC CENTER BAND TWO TONE PAINT BCQ MAINTENANCE FREE BATTERY CBA STRAIGHT BACK BENCH SEAT CGX RR HEAD RESTRAINTS OUTBOARD SEATING CKA CARPET DDQ 5-SPEED MANUAL TRANSMISSION ERB 4.0L I6 MPI ENGINE GAC TINTED GLASS WINDOWS GEC FRONT LEFT SIDE SLIDING WINDOW GFD REAR SLIDING WINDOW HCC DO NOT USE - SEE HCA JAY DO NOT USE - SEE JP, KA CLASSES JFH TACHOMETER JGB JHA VAR INTERMITTENT WINDSHIELD WIPERS JJA CIGAR LIGHTER LAP SHIFT INDICATOR WARNING LAMP LMA HALOGEN HEADLAMPS MBJ BLACK FRONT BUMPER MDA FRONT LICENSE PLATE BRACKET NAE CALIFORNIA EMISSIONS NFA 23 GALLON FUEL TANK PXB QXG SBA POWER STEERING SUA TILT STEERING COLUMN TBG COMPACT SPARE TIRE WJM 15X7.0 CHROME WHEELS XEA TOW HOOKS That's awesome! I requested an official build sheet from Jeep, but the one they sent me wasn't accurate at all Thanks for the info! Link to comment Share on other sites More sharing options...
Pete M Posted May 10, 2024 Share Posted May 10, 2024 2 hours ago, 996xj said: That's awesome! I requested an official build sheet from Jeep, but the one they sent me wasn't accurate at all Thanks for the info! the list is still just part of the whole. the early years are missing a lot of info. if you look at the 91/92s, you'll see what I mean. Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted May 11, 2024 Share Posted May 11, 2024 Sounds like the beginnings of an excellent project! In case you were wondering what the rest of the sheet looks like, I scanned mine a few months back when I found it behind the passenger side door card. Now to just finish documenting my build lol https://salvagedcircuitry.com/docs/build-sheet.jpg Link to comment Share on other sites More sharing options...
996xj Posted May 13, 2024 Author Share Posted May 13, 2024 On 5/10/2024 at 7:45 PM, Salvagedcircuit said: Sounds like the beginnings of an excellent project! In case you were wondering what the rest of the sheet looks like, I scanned mine a few months back when I found it behind the passenger side door card. Now to just finish documenting my build lol https://salvagedcircuitry.com/docs/build-sheet.jpg Thanks! Definitely been having fun rebuilding it. That build sheet is awesome though! And in great condition Link to comment Share on other sites More sharing options...
