mddrexel Posted October 31, 2023 Share Posted October 31, 2023 is there a cross reference of readily available, more common trannies that will work? Sketchy BA10's and AX's can be found but are hard to trust and trustworthy ones, if available, will cost more than the truck is worth. I don't care if it is from a different brand of vehicle, but it needs to be manual and for a 2WD, thanks for any ideas Link to comment Share on other sites More sharing options...
acfortier Posted October 31, 2023 Share Posted October 31, 2023 I think it's going to be tough to find anything other than a BA10/5 or AX-15 that will work, specifically because of the need for a CPS, so you can't work backwards. NV3550 might be doable: https://www.novak-adapt.com/knowledge/transmissions/manual/nv3550 Novak also lists other manual transmission upgrades in that same article, that won't be exactly plug-n-play but can work. Link to comment Share on other sites More sharing options...
87MJTIM Posted October 31, 2023 Share Posted October 31, 2023 You should be looking at Craiglist and Facebook for transmissions for sale. Also, search out local junk yards near you. You will want to get the AX15 and bellhousing (preferably external slave cylinder with all the internal bellhousing parts) the tcase (the one for the BA10 won't fit the AX15), the crossmember, the tcase shift linkage, and maybe more that I am forgetting. Link to comment Share on other sites More sharing options...
fiatslug87 Posted October 31, 2023 Share Posted October 31, 2023 He’s looking for 2WD. Link to comment Share on other sites More sharing options...
87MJTIM Posted November 1, 2023 Share Posted November 1, 2023 I have to RTF post. (read the f***ing) Link to comment Share on other sites More sharing options...
ghetdjc320 Posted November 1, 2023 Share Posted November 1, 2023 A 2wd ax15 would do nicely. As for cross referencing other vehicles, early dodge dakotas used the ax15. The Toyota R151 is very closely related but has the wrong input shaft. Link to comment Share on other sites More sharing options...
mddrexel Posted November 1, 2023 Author Share Posted November 1, 2023 thanks everybody for the input, I guess it's off to the junkyard for me. Maybe I'll take my wife along, that counts as a date, right? Link to comment Share on other sites More sharing options...
