mddrexel Posted October 22, 2023 Share Posted October 22, 2023 Hello all, I recently had to replace the slave cylinder in my BA 10/5 tranny. As you all probably know, this means I had to remove and replace the tranny. While doing this I pulled the shifter and it just lifted right out, when I looked on the uh, shifter hole? I noticed that the stuff that was supposed to hold it in was all broken up (the retaining ring and clip) I pulled out the parts and figured I could just but new ones but apparently nobody has these parts. My questions are; 1. has anybody else run into this problem? and B. is there a workaround? like a part from another vehicle that will fit. Any info would be greatly appreciated and of course, Thank you in advance. Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 23, 2023 Share Posted October 23, 2023 Unless you’re absolutely hard set on keeping the pukegoat BA10/5, everyone is gonna tell you to ditch it and get the AX15. And yes parts for that trans are hard to find just like the Renault turbo diesel from the early years. Link to comment Share on other sites More sharing options...
pizzaman09 Posted October 23, 2023 Share Posted October 23, 2023 The transmission was also used in the Peugeot 505, that might give you a lead for parts. What's this part supposed to look like? Can one 3d print or machine one? The typical ones I've seen are a cylindrical with a spherical surface on the one end to push against the ball. Link to comment Share on other sites More sharing options...
mddrexel Posted October 23, 2023 Author Share Posted October 23, 2023 Hi Eaglescout, thanks for the advice, I've heard about the issues with the BA10 but this one has lasted through 187,000 miles and still going strong so they can't be all bad! Plus, I don't want to swap trannies for what appears to be a less than $20 part Link to comment Share on other sites More sharing options...
Pete M Posted October 23, 2023 Share Posted October 23, 2023 it's only $20 if you can find one. maybe the parts page will help: Link to comment Share on other sites More sharing options...
mddrexel Posted October 23, 2023 Author Share Posted October 23, 2023 Hi Eaglescout, thanks for the advice, I've heard about the issues with the BA10 but this one has lasted through 187,000 miles and still going strong so they can't be all bad! Plus, I don't want to swap trannies for what appears to be a less than $20 part Hello Pizzaman, thanks, I'll try the 505 route, maybe get on some Peugeot forums. I know there is one of these parts on eBay but they want $30 plus shipping. It's just a thin washer and a retaining clip Link to comment Share on other sites More sharing options...
mddrexel Posted October 23, 2023 Author Share Posted October 23, 2023 Thanks Pete, I'll probably just get the one on eBay, I'm very cheap so it kills me to spend that much on something so little, grrr Link to comment Share on other sites More sharing options...
Pete M Posted October 23, 2023 Share Posted October 23, 2023 35 minutes ago, mddrexel said: Thanks Pete, I'll probably just get the one on eBay, I'm very cheap so it kills me to spend that much on something so little, grrr just gotta change your mindset. it's not little, it's old and rare and precious. Link to comment Share on other sites More sharing options...
JZLAJeep Posted October 23, 2023 Share Posted October 23, 2023 13 hours ago, mddrexel said: Thanks Pete, I'll probably just get the one on eBay, I'm very cheap so it kills me to spend that much on something so little, grrr We pulled the BA10/5 our of our MJ and still have it and it's shifter. We may have what you need. Link to comment Share on other sites More sharing options...
mddrexel Posted October 31, 2023 Author Share Posted October 31, 2023 Jzlajeep, thank you for the offer, and thanks to all the other members But it may be a moot point, I re-installed the tranny and after a few tests it appears that the 3rd gear synchro is shot, as it grinds going in and won't stay in gear, I knew it was worn but it always worked. When I pulled it there was only about a half pint of oil in it, I think I shocked it with new oil. The truck is very rough but the motor is very strong, though I think the old dog might be reaching the end of the line. Link to comment Share on other sites More sharing options...
pizzaman09 Posted November 2, 2023 Share Posted November 2, 2023 It might be worth throwing some special oils at it to help it out. I'm a big fan of the royal purple syncromax, it's done wonders for the warn out synchros in my various cars. Link to comment Share on other sites More sharing options...
