Can stalling my truck lock the starter?
Stalled my truck and afterwards the starter would just click when turning the key. No crank whatsoever. I had just replaced my battery and verified my alternator was working. I had bypassed the ballast resistor and it had started fine twice before that. I bought a new starter in case this one is just bad, but how could stalling make a starter die? Is it just stuck or completely dead?
Make sure all your heavy cables make good clean contact. Battery(+) to Solenoid, Solenoid to Starter and Engine Block to Battery(-). Check Starter bolts, make sure there not loose.
The hammer trick did not work. Additionally the wire which runs from the positive relay was connected using a crimp connector. Pretty awful. Turns out the replacement unit from amazon does not fit my truck. Are there any starters on rock auto that are good?
20 minutes ago, cruiser54 said:
You have a very oily starter.
Why or how doesn't the starter fit?
The starter doesn't fit because amazon sent me the completely incorrect part. I ordered it over a month ago and was busy so I didn't open it until now. I don't think I can get my money back.
It was supposed to be this:
https://www.amazon.com/dp/B007Y86TIS/ref=pe_386300_440135490_TE_simp_item_image
