JimiGibbs Posted September 11, 2023 Posted September 11, 2023 Anyone had any experience with this? Ad sounds to goo to be true for the price..... https://gainmpg.com/products/performance-chip-for-jeep-comanche?rq=yr_1989~mk_jeep~md_comanche~yg_4-0l Thanks, Jimi
Salvagedcircuit Posted September 11, 2023 Posted September 11, 2023 This is a complete scam. Quote "Our affordable performance chips work by sending a continuous signal through a factory engine data sensor that your Jeep Comanche engine control module (ECM) monitors. This modified and continuous signal triggers your vehicle's computer to safely optimize itself for a more efficient fuel mixture and timing curve, allowing the full benefits of a power programmer" Quote Is it safe to use? It is extremely safe to use! Since the performance chip does not directly interface with your factory computer or exceed any factory limitations or parameters, it is one of the most safest aftermarket devices that you can install. Above are quotes directly from the GainMPG / Innovate Performance Chips website. There is no factory data sensor on the comanche. There is a diagnostics port for reading values. That's it. If the performance chip does not directly interface with the factory computer, how can it possibly work? The photo also shows a random black anodized box, the same ones sold for $4 on aliexpress, with no photos of how it installs in the vehicle and no photos of what connector each module uses. This is one of those plug into a cigarette outlet and gain HP scams. It's a capacitor in a box. Complete scam. The entire website is a boilerplate design and was made in just a few minutes on shopify. Every page is identical for every vehicle with no differences between make or model. It is all too convenient that every make and model vehicle is supported by their tool, which would be nearly impossible. Don't give these clowns a penny. It's too bad we don't have an agency that actually responds to fraud, something like the FTC that actually does something
87MJTIM Posted September 11, 2023 Posted September 11, 2023 Reach out to Nickintime design for the REM.
cruiser54 Posted September 13, 2023 Posted September 13, 2023 Want more power? Index your distributor. 60mm throttle body. Advance your CPS. Eliminate the D crush in your exhaust downpipe.
JimiGibbs Posted September 15, 2023 Author Posted September 15, 2023 THANKS..... I thought it was to good to be true. Jimi
Pete M Posted September 15, 2023 Posted September 15, 2023 regear! best bang for the seat-of-the-pants buck.
