Awesome Posted May 22, 2025 Author Share Posted May 22, 2025 Installed new battery, still has issues at a certain RPM when floored in third gear. Starts hesitating and will backfire quietly if I keep the throttle floored. If I back off the throttle and let the RPM climb higher or drop down, then floor it again, it doesn't do it. It's only in a certain RPM range. What causes that? Link to comment Share on other sites More sharing options...
Awesome Posted June 16, 2025 Author Share Posted June 16, 2025 Daughter drove the truck today on the road. Her first time on the street and her first time driving a stick on the road. She did pretty good. Practiced some mild hill starts and some emergency stops. Bunch of low speed driving with some highway driving. She says she much prefers her truck to the TJ that she's been driving up until now. Found out why the brake pedal is a bit spongey and where the leaking fluid is coming from - the drivers rear wheel cylinder is leaking a bunch. Good thing I bought replacements already! Link to comment Share on other sites More sharing options...
Awesome Posted June 19, 2025 Author Share Posted June 19, 2025 Got the rear brakes torn apart this afternoon. Had to buy another wheel cylinder because I could only find one of the ones I bought. Discovered the shoes are pretty shot so it's going to be a full brake job. Posted in another thread trying to figure out if I can use the TJ brakes I have that are on a bad axle. Daughter drove her MJ in traffic. She did not do well under pressure and after stalling it about a dozen times trying to pull out of a parking lot, she told me I was driving. Think she may be sitting too far forward and doesn't have enough pedal control. Link to comment Share on other sites More sharing options...
Awesome Posted June 19, 2025 Author Share Posted June 19, 2025 Finished up the brake job today. Didn't take any "after" pictures. But it stops even better now and the brake pedal is no longer soft. Ended up just getting stock replacement shoes instead of trying to fit the newer TJ brakes on it. Link to comment Share on other sites More sharing options...
Awesome Posted November 16, 2025 Author Share Posted November 16, 2025 Update: Daughter has been driving her truck for a few months. It runs good, but will still hiccup under full throttle occasionally. It's not a regular occurrence anymore and I haven't heard it backfire under acceleration in a while. I guess I never posted what we were doing to try and fix those issues; I ended up replacing the TPS, the MAP sensor and checking all the wiring. Replacing the MAP sensor made the biggest difference, as the old one had failed. The old TPS had some bad spots in it. After clearing the long-term memory a few times, the truck idles smoother, accelerates better and overall just runs better. We put a new brake master in it last week and power bled the brake system. I replaced the vacuum booster check valve and grommet. It is now possible to lock up the tires. We're still working on it, slowly. I hope to have the interior finished before the end of the year. Link to comment Share on other sites More sharing options...
Awesome Posted December 4, 2025 Author Share Posted December 4, 2025 Well, we got the dash moved finally. And I'm disappointed. I was expecting to be able to get to the air intake port and seal it. That does not look to be possible without removing the entire HVAC box. Bummer. So I guess we'll be disconnecting the dash and then working on getting the HVAC box removed. Might as well swap in A/C while I'm at it. I noticed a few days ago that the truck seemed to be riding a lot rougher than normal. Normally rides very nice. Today, my daughter said it was bouncing all over the place so much that she was hitting the roof. I noticed a bunch of oil all over the drivers side wheel well. I think the shock seized and then exploded. I'll have to see if the Ranchos I have will fit her truck. Link to comment Share on other sites More sharing options...
Awesome Posted December 6, 2025 Author Share Posted December 6, 2025 I was told that because the firewall is different, none of the post-'86 HVAC boxes will fit this truck. DOUBLE BUMMER. I've had one-off year vehicles before and I didn't learn from it, apparently. I am now considering cutting an access panel in the cowl instead of trying to remove the entire HVAC box. But... I probably should replace the heater core anyway. So. Link to comment Share on other sites More sharing options...
Awesome Posted January 14 Author Share Posted January 14 Well the last few weeks have been spent on building this: Built for a show by my daughter. She designed and built it. I didn't like the aftermarket bumpers that require cutting the grille to fit the winch, so we built around those design flaws. Once the show is over we'll get back to working on her truck. EDIT: She got sixth place. She's bummed, but the bumper was extremely popular with spectators and she gets to install it on her truck anyway. Link to comment Share on other sites More sharing options...
Awesome Posted February 4 Author Share Posted February 4 IT BEGINS: 2-4-26 Link to comment Share on other sites More sharing options...
Awesome Posted February 22 Author Share Posted February 22 Ok, back to the '86. Today I fixed the tailgate so it's "permanently" mounted. Will be pretty difficult for the common thief to walk by and steal the tailgate. We got the entire dash and HVAC box finally pulled. Pretty easy to tell how and where it was leaking from the cowl now, but I have questions: Where do I buy new seals, new foam, and new components? The blower motor does not work, so that needs to be replaced, the heater core looks ok but is 40 years old so it should probably be replaced, and all of the foam needs to be replaced as well as the rubber seal for the air inlet. I've never done this before so I don't know where to find the parts. I know a few of you have done it. Link to comment Share on other sites More sharing options...
Warthog Posted February 23 Share Posted February 23 23 hours ago, Awesome said: Ok, back to the '86. Today I fixed the tailgate so it's "permanently" mounted. Will be pretty difficult for the common thief to walk by and steal the tailgate. We got the entire dash and HVAC box finally pulled. Pretty easy to tell how and where it was leaking from the cowl now, but I have questions: Where do I buy new seals, new foam, and new components? The blower motor does not work, so that needs to be replaced, the heater core looks ok but is 40 years old so it should probably be replaced, and all of the foam needs to be replaced as well as the rubber seal for the air inlet. I've never done this before so I don't know where to find the parts. I know a few of you have done it. There’s a guy on the Cherokee forums that’s makin em or was. Great stuff! Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted February 23 Share Posted February 23 21 hours ago, Awesome said: Where do I buy new seals, new foam, and new components? Hit up @H3ADBANG4L1F3. I don't know if any thing came of this project but the pictures prototypes looked good. Link to comment Share on other sites More sharing options...
Awesome Posted February 23 Author Share Posted February 23 Thanks; I sent him a PM. Hope he responds. Not really looking forward to custom-bodging it all myself. Link to comment Share on other sites More sharing options...
H3ADBANG4L1F3 Posted February 23 Share Posted February 23 1 hour ago, Eagle_SX4 said: Hit up @H3ADBANG4L1F3. I don't know if any thing came of this project but the pictures prototypes looked good. Appreciate the shout! Life got in the way and I had to put a hold on a lot of things. Now that everything is settling down I'll set back to work on getting production up and running for y'all, I even made a few upgrades in the meantime! Link to comment Share on other sites More sharing options...
Awesome Posted yesterday at 03:49 AM Author Share Posted yesterday at 03:49 AM We found the water leak under the dash. It wasn't the heater box. Now that I see how the heater box is set up, I'm not sure how you'd get a leak through there unless the cowl rusted out. The computer mount is spot welded to the bottom of the cowl up under the dash. One of the spot welds broke free and tore out of the cowl. It was right under the wiper motor, which is why we couldn't see it before. We're going to drill out the spot welds and bolt the bracket on with stainless steel bolts and some body sealer. Link to comment Share on other sites More sharing options...
