New windshield woes
So my 3 year old windshield started leaking in the upper corners. My lifetime leak warranty would come in handy if the place I got it done at didn't close up shop (starting to makes sense why mine is leaking...)
Anyway, I called around to a bunch of places and was quoted around $400, and that they can only find 1 windshield in the entire area. One shop flat out refused to do it because it was "so old and a classic and his guys wouldn't know how to do it". Seems wild to me. I'd like to keep it the original because I love the chrome molding. Just is crazy to me. It's they key issue all over again where no one could cut an old key. Are these trucks just getting to the point where I need to find a legit classic car shop?
side note, you may (or may not) need to nip off the metal tabs if you go with the rubber trim.  some guys found they interfered with the rubber, most did not.  my best guess is some sort of inconsistency with different manufacturers of the trim?  dunno.  I'm in the middle of this swap and since we found a bit of surface rust under the glass and the whole process stopped for me to deal with it anyways, I nipped them off just to be on the safe side.
Why not just pop off the stainless trim, re-seal the glass, and reinstall the trim? If it doesn't work, you can always have the windshield replaced later. If it does work, you saved $390 ($400 less the price of a tube of RTV).
I tried that before on the old windshield and it didn't work. I guess I could give it a shot this time. But Ive read RTV isn't good for paint as it will eat away at it.
34 minutes ago, Pete M said:
if you get it replaced, make dang sure that the gluing surface on the truck is in perfect condition.  if the last guy was in a hurry, he may have tried bonding to a flawed surface. :(
I think the surface was okay. I do remember it being blistering cold that morning because I wanted to reschedule but they assured me it was fine. Maybe it didn't adhere fully?
I would check and see if your insurance would cover it.My insurance company will replace the glass for free as I have comprehensive. Especially if it’s got chips\Nicks In your line of sight they typically don’t repair those. I would also advise you To get the molding clips ahead of time as most glass shops don’t have them in stock. The clips (especially if they’re brittle ) will break easily. The clips are only around 20 bucks if you shop around, sometimes cheaper. If i recall correctly you need 17 of them
I bought 2 packs originally when I got the windshield replaced before. I was shocked to find them available new.
I feel like if there was even some rust in the channel the first window guys would definitely have said something so I feel like I should be okay. I hope anyway.
the fact that it failed after such a short amount of time wouldn't fill me with hope of any kind.  :(  he clearly did something wrong.  mine had the slightest surface rust in a few spots, but the installer refused to go further until I address it.  rear window had the same thing going on.
So I found a Windshield guy that is coming out to remove the glass for me and I'm going to take care of whatever lies underneath, then he'll come back and install a new one. What's the best method for cleaning the channel up and also what type of paint should be used.
The TDS for most window urethanes indicates there should be no paint in the jamb. Only fully cured 2 part epoxy primer (note that even the factory ignored this). On my build I primed then seam sealed the corners and primed again.
18 minutes ago, 70barracuda said:
Welp definitely some problem areas. Gotta address this. The glass guy also said that the other installer had left alot of the butyl strip in the channel too.
Wire wheel best method for cleaning?
I used one of those oscillating tools with a fine metal blade. It works excellent and save a lot of time removing all the old urethane. Also cleans up the rust very nicely. I would suggest some POR15 followed by some good medium bodied 2 part seam sealer in those corner seams. The medium bodied stuff should flow into the seams a bit. When it’s all done, mask off surrounding areas and shoot it with 2 part Roxy primer and let that cure before installing the windshield
2 minutes ago, 70barracuda said:
I got some por15 that's specific for windshield channels so that also has seam sealer in it. Then I'm going to get this paint. Should work right?
Yep that should work. Just give that aersosol 2 part epoxy some heat to cure if you can. Once it dries to the touch and is no longer soft, hit it with a heat gun, heat lamp or just leave it in the sun for several hours. I’ve noticed the aerosol 2k primers take longer to cure as hard as the ones you mix and shoot in a gun. If you can, I’d even give it a few days to cure.
Thanks for the tips. Unfortunately having no garage means this is gonna suck for painting. It's been 40s at night and 50s during the day with nonstop rain so I'm hoping it clears up. Want to get this done asap, but also want to do a really good job.
