Whitaker717 Posted February 4, 2023 Share Posted February 4, 2023 Just a quick question guys. I am replacing the trim around the window and I am not sure if the trim slides over the thin metal along the window or it just sits in the clips. Hope that makes sense. Link to comment Share on other sites More sharing options...
jpnjake Posted February 4, 2023 Share Posted February 4, 2023 that helped me take my trim off when I polished one side of my trim Link to comment Share on other sites More sharing options...
pizzaman09 Posted February 6, 2023 Share Posted February 6, 2023 It slides over. I used the rubber coated handle of a pair of pliers I owned to protect the top edge of it then a small hammer to knock it in place. They should be a tight fit. Link to comment Share on other sites More sharing options...
Whitaker717 Posted February 7, 2023 Author Share Posted February 7, 2023 2 hours ago, pizzaman09 said: It slides over. I used the rubber coated handle of a pair of pliers I owned to protect the top edge of it then a small hammer to knock it in place. They should be a tight fit. When you say slides over you mean the sheet metal slides up in the trim? Link to comment Share on other sites More sharing options...
AZJeff Posted February 7, 2023 Share Posted February 7, 2023 1 hour ago, Whitaker717 said: When you say slides over you mean the sheet metal slides up in the trim? YES, that is correct. Link to comment Share on other sites More sharing options...
Whitaker717 Posted February 7, 2023 Author Share Posted February 7, 2023 Just now, AZJeff said: YES, that is correct. Thanks. You don’t happen to have pictures do you. I think my trim is just sitting in the clips on the bottom where the felt is. Link to comment Share on other sites More sharing options...
AZJeff Posted February 7, 2023 Share Posted February 7, 2023 No, I do not, unfortunately. Link to comment Share on other sites More sharing options...
pizzaman09 Posted February 7, 2023 Share Posted February 7, 2023 It seats such that it covers all the sheet metal down to the bend. Picture shows proper placement. Link to comment Share on other sites More sharing options...
jpnjake Posted February 7, 2023 Share Posted February 7, 2023 Here’s some pictures it’s slightly different on the 97-01 as pictured but the same basic design except the bottom peice on the old style is held on with metal clips and is 2 peice where the new is just one Link to comment Share on other sites More sharing options...
garyweb3 Posted February 9, 2023 Share Posted February 9, 2023 I just received and installed a new set of window felt beltline weatherstrips from Steele Rubber Products on my 87 Comanche. 4pcs inside and out. Looks and fits like OEM in case anybody is looking to replace theirs. About $100 w/tax and shipping. Link to comment Share on other sites More sharing options...
Whitaker717 Posted February 9, 2023 Author Share Posted February 9, 2023 Thanks guys, my sheet metal is a bit bent up and I can’t seem to get the trim to go over the sheet metal and 3 clips attached to window felt. Link to comment Share on other sites More sharing options...
