Armyvet25 Posted February 2, 2023 Share Posted February 2, 2023 What is the D35 width on a Comanche axle from wheel to mating drum surface to opposite drum surface distance? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 2, 2023 Share Posted February 2, 2023 11 minutes ago, armyvet25 said: What is the D35 width on a Comanche axle from wheel to mating drum surface to opposite drum surface distance? Around 61”. 63” width fits really nice in the back of an MJ with stock is similar backspacing Link to comment Share on other sites More sharing options...
Armyvet25 Posted February 2, 2023 Share Posted February 2, 2023 1 minute ago, ghetdjc320 said: Around 61”. 63” width fits really nice in the back of an MJ with stock is similar backspacing Link to comment Share on other sites More sharing options...
Joe Dirt Posted February 3, 2023 Author Share Posted February 3, 2023 Well the guy with the 35/12.5-17s sold em. Wtf. I need a set of rims and tires bad n don't have brand new kind of cash on hand right now. Wal-Mart has a nice set of good year 31/10.5-15s like $645 before mount n balance. Dude wanted 750 for the 35s. Oh well, just my luck..... Link to comment Share on other sites More sharing options...
JZLAJeep Posted February 3, 2023 Share Posted February 3, 2023 35 minutes ago, Joe Dirt said: Well the guy with the 35/12.5-17s sold em. Wtf. I need a set of rims and tires bad n don't have brand new kind of cash on hand right now. Wal-Mart has a nice set of good year 31/10.5-15s like $645 before mount n balance. Dude wanted 750 for the 35s. Oh well, just my luck..... I feel your pain. I needed newer tires for our Comanche as the tires that were on it when we got it were completely sun rotten (but still held air after being filled amazingly). 5 new tires (235/75/15) would have been $1200; the Comanche had only cost us $600. I ended up finding four used tires (30/9.5/15 I think...) for $350 mounted and then found another set of four tires and wheels (235/75/15) for $400. With 2 Cherokees and 1 Comanche they'll get used on something... So don't give up yet. They are out there. You may end up going from being tire poor to tire rich like I did. Link to comment Share on other sites More sharing options...
Armyvet25 Posted February 3, 2023 Share Posted February 3, 2023 um, you were looking at 17" tires, what rims were you going to use? Link to comment Share on other sites More sharing options...
Armyvet25 Posted February 3, 2023 Share Posted February 3, 2023 some info on different axles sought after for replacement axle comparisons Link to comment Share on other sites More sharing options...
Joe Dirt Posted February 3, 2023 Author Share Posted February 3, 2023 1 hour ago, armyvet25 said: um, you were looking at 17" tires, what rims were you going to use? They came with rims. They looked like pro-comp. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 3, 2023 Share Posted February 3, 2023 1 hour ago, armyvet25 said: some info on different axles sought after for replacement axle comparisons That link generalizes a lot of info and is missing a lot too. Here are a couple examples: The D30HP is an inherently superior design for a front axle and the better use of the gear set makes it stronger than the LP D30 (all non rubicon TJ’s and 99.5+ XJs). It’s also missing info on the JK D30’s which were also a stronger design. 2007 JK’s also had a D35 option and the modern D35 is the standard axle in JL and JT platforms. The D44 HD gearset was introduced long before the JK made the gearset popular or well known Link to comment Share on other sites More sharing options...
Armyvet25 Posted February 3, 2023 Share Posted February 3, 2023 was just adding the info, figured it wasn't all inclusive, since the D35 in my Comanche has bolt on's, and won't be rock climbing, I should be good with 33's Link to comment Share on other sites More sharing options...
Pete M Posted February 3, 2023 Share Posted February 3, 2023 12 minutes ago, armyvet25 said: was just adding the info, figured it wasn't all inclusive, since the D35 in my Comanche has bolt on's, and won't be rock climbing, I should be good with 33's what gear ratio will you running with those 33s? Link to comment Share on other sites More sharing options...
Armyvet25 Posted February 3, 2023 Share Posted February 3, 2023 Just now, Pete M said: what gear ratio will you running with those 33s? not sure, current is either 30...somthing or 331 something....I want 3:73 Link to comment Share on other sites More sharing options...
Armyvet25 Posted February 3, 2023 Share Posted February 3, 2023 to be honest, in current configuration I'm not worried about the D35 as much as that poor old 2.8, I won't be going to the 33's till I get drive train and axle ratio worked out Link to comment Share on other sites More sharing options...
89 MJ Posted February 3, 2023 Share Posted February 3, 2023 With 33s, I’d run 4.10s or 4.56s. Those will still give you plenty of ability to do 70 and it will make the truck seem less like a dog. Link to comment Share on other sites More sharing options...
Pete M Posted February 3, 2023 Share Posted February 3, 2023 I have 4.10s now and I kinda want 4.88s for my 33s. Link to comment Share on other sites More sharing options...
Joe Dirt Posted February 3, 2023 Author Share Posted February 3, 2023 Since the guy sold the 35s i was thinking of using the 33/12.5s off my parts truck. Whats the deal with my 4.30 with 33s? Link to comment Share on other sites More sharing options...
Pete M Posted February 3, 2023 Share Posted February 3, 2023 4.30? Link to comment Share on other sites More sharing options...
Joe Dirt Posted February 4, 2023 Author Share Posted February 4, 2023 22 hours ago, Pete M said: 4.30? Idk what i was thinking. I meant 3.07 and to be completely honest idk what's in it..... Link to comment Share on other sites More sharing options...
Pete M Posted February 4, 2023 Share Posted February 4, 2023 2 hours ago, Joe Dirt said: Idk what i was thinking. I meant 3.07 and to be completely honest idk what's in it..... quick and dirty way is to jack up one rear tire, put the trans or t-case in neutral, and rotate the tire around exactly twice while counting the times the driveshaft rotates. 3 and a half is 3.55, just over 4 is 4.10, etc. if it has a posi, you need to jack up both tires and rotate them just once. Link to comment Share on other sites More sharing options...
Joe Dirt Posted February 5, 2023 Author Share Posted February 5, 2023 13 hours ago, Pete M said: quick and dirty way is to jack up one rear tire, put the trans or t-case in neutral, and rotate the tire around exactly twice while counting the times the driveshaft rotates. 3 and a half is 3.55, just over 4 is 4.10, etc. if it has a posi, you need to jack up both tires and rotate them just once. One thing i definitely know is it's an open dif. She's a 1 wheel peel.... Link to comment Share on other sites More sharing options...
Joe Dirt Posted February 5, 2023 Author Share Posted February 5, 2023 16 hours ago, Pete M said: quick and dirty way is to jack up one rear tire, put the trans or t-case in neutral, and rotate the tire around exactly twice while counting the times the driveshaft rotates. 3 and a half is 3.55, just over 4 is 4.10, etc. if it has a posi, you need to jack up both tires and rotate them just once. Just wanted to let you know. That was like the best tech tip I've gotten in a hot minute. I'm so happy i joined this page. Link to comment Share on other sites More sharing options...
Pete M Posted February 5, 2023 Share Posted February 5, 2023 3 hours ago, Joe Dirt said: One thing i definitely know is it's an open dif. She's a 1 wheel peel.... the stock posi is a clutch based unit and after it wears out, it will do the same. but they are kinda rare so it's probably just open. Link to comment Share on other sites More sharing options...
Joe Dirt Posted February 5, 2023 Author Share Posted February 5, 2023 3 hours ago, Pete M said: the stock posi is a clutch based unit and after it wears out, it will do the same. but they are kinda rare so it's probably just open. I still have to go take pictures so maybe you guys can maybe tell me what rear is in this rust bucket. Like i said b4 it has perches on top someone cut to make room for u-bolts. I'm gomma be working on it tomorrow so ill put the pics up. Link to comment Share on other sites More sharing options...
Armyvet25 Posted February 5, 2023 Share Posted February 5, 2023 thoughts on a 5 lug 12 bolt Chrysler 9.25 from a Dodge Ram, everything I've read says better stronger than Dana 44 Link to comment Share on other sites More sharing options...
Pete M Posted February 5, 2023 Share Posted February 5, 2023 27 minutes ago, armyvet25 said: thoughts on a 5 lug 12 bolt Chrysler 9.25 from a Dodge Ram, everything I've read says better stronger than Dana 44 wouldn't that be a 5 on 5.5 bolt pattern? either way it is stronger than a 44, but marginally. I'd still lump it in the d44/8.8/97+8.25/9" family. V8 capable for sure, but not dana 60 levels of strong. Link to comment Share on other sites More sharing options...
