87 MJ Chief Posted January 12, 2023 Share Posted January 12, 2023 We'll call it a trivia question so that way I don't look stupid! Lol Can someone identify the grey electrical part that's forward of the oil pressure sensor, at 2:00 from the oil filter? This is on a 2000 4.0. Thanks!! Link to comment Share on other sites More sharing options...
Ωhm Posted January 12, 2023 Share Posted January 12, 2023 Camshaft Position Sensor aka SYNC sensor. Link to comment Share on other sites More sharing options...
87 MJ Chief Posted January 12, 2023 Author Share Posted January 12, 2023 Can it go bad and leak oil? Ding! Ding! Winner of the trivia question! (Shew, bout forgot that!) Link to comment Share on other sites More sharing options...
jpnjake Posted January 12, 2023 Share Posted January 12, 2023 1 minute ago, Ωhm said: Camshaft Position Sensor aka SYNC sensor. Damn it you beat me too it. It replaces the distributor as 2000+ motors are coil on plug also drives the oil pump like the distributor Link to comment Share on other sites More sharing options...
87 MJ Chief Posted January 12, 2023 Author Share Posted January 12, 2023 @jpnjakegets honorable mention. Something in this picture is leaking but I can't put my oily finger on it. Link to comment Share on other sites More sharing options...
WranglerMangler Posted January 12, 2023 Share Posted January 12, 2023 Buy 2 of these kits, they’re about $5ea. It’s for your oil filter adapter, use one kit to reseal your oil filter adapter and use the O ring from the other kit that fits for your OPDA. (Oil Pump Drive Assembly.)To re seal the OPDA. I purchased the O ring that Cruiser54 suggested from NAPA but found the one in this kit to fit better. This is regarding a ‘91 HO. Assuming the diameter of the ‘91 distributor and the 2000 OPDA are the same. I have also had Oil pressure sending units just randomly start leaking from the threads and out of the side of the sending unit body. Check that too. And always grab them from the Junkyard when you see them, Napa is really proud of their oil pressure sending units for my ‘91. Link to comment Share on other sites More sharing options...
cruiser54 Posted January 12, 2023 Share Posted January 12, 2023 Is that a DENTED Fram oil filter on there? Fram sucks!!! Link to comment Share on other sites More sharing options...
75sv1 Posted January 12, 2023 Share Posted January 12, 2023 Also, there is an oil seal for the distributor. Link to comment Share on other sites More sharing options...
87 MJ Chief Posted January 13, 2023 Author Share Posted January 13, 2023 Thank you @WranglerMangler. I will put that on the "must do" list. Mr. @cruiser54, it's a shadow'd FramCrap filter that's getting changed out in the next couple of days with a Mopar filter. Link to comment Share on other sites More sharing options...
WranglerMangler Posted January 14, 2023 Share Posted January 14, 2023 I put that job off for a while not wanting to screw with my Distributor, and had read about difficulties getting the oil filter adapter removed, In my recent experience with it, it was laughably easy. Buy yourself a new oil filter and the kits, and jump right in. Suggest Getting some super clean while your there, soak it down and pressure wash the area for easier oil leak diagnostics. Link to comment Share on other sites More sharing options...
