90 Comanche 4.0 fuel smell
Ok guys even after sitting all night. When you walk up to the jeep all you can smell is fuel underneath. There are no wet spots on drive and no visible leaks that I can find. The only thing is when I put my nose to the catalytic convertor I smell gas. Any ideas what could be going on
I let it idle in the drive for awhile no fuel smell from exhaust. But I noticed when I put My tachometer on it. It fluctuates between 11and 1300 rpm. Then after driving the truck for awhile it jumps to 1600 rpm idling. If I shut the truck of and let it sit a bit It will idle at 1100 again. I have done all of cruisers renix tips. Nothing seems to help and after driving awhile I start getting a surge feeling at 45 to 55. This truck is a problem child that I can't seem to get figured out
41 minutes ago, comanche32 said:
I have tested all sensors and checked for vacuum leaks. I replaced the the tps. I haven't checked the intake manifold bolts
which technique did you use for finding vacuum leaks?  I've found sometimes propane works better but other times carb cleaner works better.
I had time to take the jeep on a pretty long drive. The fuel smell is coming out of the exhaust I believe. I couldn't smell anything by the canister. And I noticed while driving there's a tick coming from the driver's side the engine. Almost like a spark knock sound. The more you get on the gas the louder the tick. I'm wondering of I have a intake gasket bad
If you don't in fact have a cracked exhaust manifold you most certainly have an issue with that rear lower bolt.  You could very likely have a gasket leak there causing an exhaust leak and said ticking.  If indeed the bolt is missing you're lucky.  Mine was broken off at the head.  Make sure that that is not the case, if so, you will need to pull the intake/exhaust manifold.  Also if you're lucky you may be able to extract it with an easy out.  You'll need a right angle drill adapter and a short cobalt bit to do the job.
I was not so lucky.  I ended up pulling the head and having the bolt hole helicoiled after I had it completely buggered.  Take the head to a machine shop and have them pressure test it and if it is good then have it milled.  All in all I suppose the ever increasing immersion into the morass of a broken lower rear manifold bolt was good.  My head had to be taken down 13 thousandths to get it flat.  It also needed extensive cleaning of the hardened remains of having been immersed in the Le Brea tar pit for a decade or two.  Why is everything so dam hard?
I wish you luck!
If you're smelling fuel with the truck sitting static overnight probably not manifold related.
Tank gasket leaking is my bet - mine leaks at the top 1/3 of the gasket - if I fill the tank it stinks like hell until it gets down to 3/4 tank.
Been like that since day 1 - got the replacement gasket but every time I get under there to swap it out I find something else and get sidetracked - last time discovered a frayed ebrake cable and that turned into a bigger project than anticipated.
