72cut Posted November 8, 2022 Share Posted November 8, 2022 Couple pics. First pic is piece on side of air box, other end of hose not attached, what is it, where does it go . Second pic is ground wire on firewall, what us this ground for, where are others? Thanks Link to comment Share on other sites More sharing options...
pizzaman09 Posted November 8, 2022 Share Posted November 8, 2022 That is the main ground strap for the engine, goes to a stud on the back of the head. Definitely follow Cruiser's tips to check over all your electrical system if the truck is new to you. Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 8, 2022 Share Posted November 8, 2022 The first image is the air blend door. Vacuum goes to it to close off fresh air and bring in hot air from the exhaust manifold. Link to comment Share on other sites More sharing options...
72cut Posted November 8, 2022 Author Share Posted November 8, 2022 What does other end attach to Link to comment Share on other sites More sharing options...
Ωhm Posted November 9, 2022 Share Posted November 9, 2022 Link to comment Share on other sites More sharing options...
72cut Posted November 9, 2022 Author Share Posted November 9, 2022 Air blend door? Don't see it on diagram. Is it a vacuum motor Link to comment Share on other sites More sharing options...
Ωhm Posted November 9, 2022 Share Posted November 9, 2022 Yea, vacuum motor/air blend door same thing. Link to comment Share on other sites More sharing options...
cruiser54 Posted November 9, 2022 Share Posted November 9, 2022 14 hours ago, 72cut said: Couple pics. First pic is piece on side of air box, other end of hose not attached, what is it, where does it go . Second pic is ground wire on firewall, what us this ground for, where are others? Thanks See Tips 1 through 5 at www.cruiser54.com Link to comment Share on other sites More sharing options...
72cut Posted November 9, 2022 Author Share Posted November 9, 2022 Thanks Link to comment Share on other sites More sharing options...
