72cut
Everything posted by 72cut
  1. Thank you
  2. Anyone know if Goodyear wrangler in 235 75 15 size will rub at full turn with stock jeep steel wheels? Also any recommendations on under $100 tires in that size, other than the wranglers that are quality and won't rub?
  3. Ok thanks what should i start with telay harness or switch?
  4. Havent installed anything. Is relay harness same as switch? Novice question
  5. 88 mj4.0 Left blinker works. When i try right blinker all blinkers come on as if i turned hazards on. Also, headlights work but won't go off when i push in switch. They won't go off until i disconnect battery. Also tail lights. What is going on?
  6. Thanks my friend
  7. Just bught a group 34 for my 88 4.0. It is 7 inches tall, 10 long, 6 deep. Should this physically fit? Asking because i don't want to try to fit it, scratch ut and find out it doesnt fit. If scratched may have hard time returning
  8. It's an 88 with 4.0, haven't checked manual yet and for some inexplicable reason I didn't check the hazard button. Will tomorrow. Also, cargo light meaning the bed light on back of cab?
  9. Hello everyone couple electrical questions. Have my truck running, idling and moving without overheating which is good. However, when I tested my blinkers I noticed that regardless of which one I tried both lenses lit up in back as if the hazards were on. Now on my dash I have following switch. What is it and does it have anything to do with blinkers? Incidentally it is always lit up regardless of position. Also the light above the bed is always on
  10. 72cut
    1JTMR65P9JT137646
    Thank you!
  11. Ive looked at 3-4 sources, all different Yeah I'm at a loss here
  12. Thanks to all
  13. Where does this line go? Thought it went to EGR valve but EGR valve already has hose on it. Also I currently have the other one running to white circular part front of air box. Coreect?
  14. 72cut
    1JTMR65P9JT137646
    1JTMR65P9JT137646 1988 comanche pioneer 4.0, auto, 7 ft bed, 4x4 Blue/gray gray interior, bucket seats Maryland Unknown transfer case believed to be original Used as farm truck Many years
  15. Didn't think so debating on whether to keep it
  16. 88 comanche does this bed look like one that would have come from factory?
  17. 88 comanche 4.0 Nauseating black smoke coming out of exhaust. I mean this stuff is nauseating feel it in your head, sinuses, makes you gag. What are potential causes just put new fuel pump on
  18. Ok guys I just put a new fuel pump in my 88 lab, I eventually want to put a new tank on. Yes, I've read previous posts and I've read about 16, 18 and 23.5 gallon tanks. Different people say different things. I can tell you I felt 2 baffles on bottom of tank and I think it has 3 straps. So question is, is there a definitive way to tell by looking at it? If not and I currently have 16 or 18 gallon and I buy a 23 gallon by mistake will pump still work or vice versa. What do I have?
  19. Ok will start it and see how high it goes
  20. Thank you will try to get pic
  21. Just put new fuel pump in my truck I now have dark black smoke coming from exhaust, never had this before. What is this indicative of with these trucks? Secondly next to the new fuel hoses I just put on at fuel tank there is a vacuum line. It runs to the rail and joins a metal Iine. The end near the hoses is sheared off and I have no idea what it is supposed to attach to. Any ideas?
  22. I have an 88 with 4.0 It has new radiator, water pump? Thermo, hoses, fuel pump and lines. Question 1 ( yes I'm sure this has been exhaustively covered but my other two questions prob haven't so stick with me) As stated truck has new radiator, pump and thermo So I'm running the truck for first time since these things have been installed so I know there is air in system. When truck idles the temp approaches 210 when I turn it off. Hoses get hot, fluid Still drains from reservoir after truck is turned off and air still escapes when I loosen the cap so I'm still bleeding it. Now, is 210 normal? I've never let it go beyond that so I don't know how high it will go but what is normal? Because of length of this question I'll address the other two questions in separate post
  23. Thanks all
