In need of Help please ELECTRICAL
27 minutes ago, AbreedApart89South said:
There is a linkable fuse on a yellow wire then a then two other wires red but one way thicker then the other red that said true ignition on HOT while crank.
that all looks aftermarket
18 hours ago, AbreedApart89South said:
The flat blade like connector (your index finger is on) plugs into the ignition switch on top of the steering column.
But more importantly, please post more pics of that Cookie Monster carpet!
